Blonk Iconoclast Donating Members 4,330 Member For: 20y 1m 23d Gender: Male Location: CH Posted 17/02/06 12:18 PM Share Posted 17/02/06 12:18 PM Yes, but technically they are virtually identical. In its physical and chemical composition. Like bringing out the BarraT engine with 220kw's in a conservitive car.More options for unsatisfied consumers.Like putting cheese on junior burgers....All about marketing and the sheep they call the public.....Mobil 1 = Mobil 1 a hugely expensive oil to research design and produce, but marketing people have told them they need to have options for consumers or they will loose sales to companies that sell oil in yellow or green or flourecent bottles... Or have picture of naked women on the packaging.......Get this now.. Mobil 1 = Mobil 1 Link to comment Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 20y 2m 26d Gender: Male Location: Perth, WA Posted 17/02/06 12:23 PM Share Posted 17/02/06 12:23 PM I would buy oil with a naked chick on the front of it... Link to comment Share on other sites More sharing options...
Blonk Iconoclast Donating Members 4,330 Member For: 20y 1m 23d Gender: Male Location: CH Posted 17/02/06 12:41 PM Share Posted 17/02/06 12:41 PM Me too........... Link to comment Share on other sites More sharing options...
cobrav8 Member 1,969 Member For: 19y 7m 27d Gender: Male Location: New Zealand Posted 19/02/06 10:39 PM Share Posted 19/02/06 10:39 PM How do you get her out of the bottle? Link to comment Share on other sites More sharing options...
turbomuz Member 209 Member For: 19y 6m 6d Location: Canberra Posted 20/02/06 05:19 AM Share Posted 20/02/06 05:19 AM Mobil 1 - Is just thatMobil 1 (there is only 1)I ran it exclusively in the T and now in the Phoon.<{POST_SNAPBACK}>What are you talking about dude?There are several different viscosity ratings for mobil 1 available. Although some are harder to find in stores than others.0W-4010W-305W-5015W-50http://www.mobil.com/Australia-English/LCW...ces/Mobil_1.asp<{POST_SNAPBACK}>Duuuude...............Mobil 1Run it in your car and you will be OK....Do you get it yet????Ask Mobil for the Data sheets and you will see there is absolutely no difference between the products you mention....Mobil 1 is the same product no matter how they package it.... Just make sure you change it every 8000 max. and do not push your car in above 35 degree air temp....Oils are oils......<{POST_SNAPBACK}>Blonk are you suggesting that Mobil is guilty of false and misleading advertising?Here are two examples from their website.Mobil 1 10W-30 SAE Grade 10W-30 Viscosity, ASTM D 445 cSt @ 40º C 62 cSt @ 100º C 10.0 Viscosity Index, ASTM D 2270 147 Sulfated Ash, wt%, ASTM D 874 1.0 HTHS Viscosity, mPa·s @ 150ºC ASTM D 4683 3.14 Pour Point, ºC, ASTM D 97 -45 Flash Point, ºC, ASTM D 92 224 Density @15º C kg/l, ASTM D 4052 0.86 Mobil 1 0W-40 SAE Grade 0W-40 Viscosity, ASTM D 445 cSt @ 40º C 80 cSt @ 100º C 14.3 Viscosity Index, ASTM D 2270 187 Sulfated Ash, wt%, ASTM D 874 1.2 HTHS Viscosity, mPa·s @ 150ºC ASTM D 4683 3.6 Pour Point, ºC, ASTM D 97 -54 Flash Point, ºC, ASTM D 92 236 Density @15º C kg/l, ASTM D 4052 0.855 Whilst I don't understand half of that garbage, there is a distinct difference. Are you saying that they are an identical oil in a different bottle? Link to comment Share on other sites More sharing options...
turbotom Team Bute Donating Members 1,550 Member For: 21y 4m 4d Gender: Male Location: Adelaide Posted 20/02/06 05:47 AM Share Posted 20/02/06 05:47 AM How do you get her out of the bottle?Rub real hard with your eyes closed! Link to comment Share on other sites More sharing options...
turbotom Team Bute Donating Members 1,550 Member For: 21y 4m 4d Gender: Male Location: Adelaide Posted 20/02/06 05:53 AM Share Posted 20/02/06 05:53 AM I'm no oil expert, and I've been using magnatec, as that's what my dealer uses.In selecting an oil, if I was living down in Tassie, and drove like a old codger all the time, I'd go for the 10w30 mix.If I was up north in the NT, with the no limit open road speed, and temps above 30 most of the year, I'd consider the heavier 10w50 oil.I've always thought that 0wXX oil was a bit too thin unless you live above the snow line in the blue mountains) and would cause a fair bit of oil loss due to seepage past the rings.....Like I said, I use the magnatec, but change it every 5000 km. Can get lots of magnatec for the price of Mobil 1. tom Link to comment Share on other sites More sharing options...
xrhp6 Member 39 Member For: 20y 10m 26d Location: Melbourne Posted 20/02/06 08:20 AM Share Posted 20/02/06 08:20 AM Use either Castrol Edge 0w-40, or Mobil1 0w-40 or 5w-50.If I could afford the expense my choice would be Castrol.They are all good Oils. Link to comment Share on other sites More sharing options...
O2STOCK Donating Members 607 Member For: 19y 2m 5d Location: Brisbane Posted 20/02/06 09:59 AM Share Posted 20/02/06 09:59 AM Just dropped my T off for the 15K service today and had the same discussion with the FORD dealer. To my supprise he said the same as F.I.S.T performance here in Brisbane said 5W-50 Mobil 1 if you can afford it or stick to the Castrol Synthetic. At high temps the turbo needs a thicker oil 0w (Weight) is to thin and at high ambiant temps will cause problems.Here in the last few months it has not got below 26 deg at night most days in the 34 - 37 deg via the outside temp probe on the T.F.I.S.T have always reccomended to me the 5W-50 Mobil 1. in some of there cars 300RWKW + must be OK. Link to comment Share on other sites More sharing options...
xlr8ed Phantom lives Member 1,417 Member For: 20y 6m 29d Gender: Male Location: who knows Posted 21/02/06 12:59 AM Share Posted 21/02/06 12:59 AM Mobil 1 nothing else..... Link to comment Share on other sites More sharing options...
