snero3 Member 5 Member For: 19y 17d Posted 16/02/06 08:32 AM Share Posted 16/02/06 08:32 AM (edited) I just brought an BA XR6T back in december. I love the car to bits but it has developed a "wosh wosh" noise from the rear end. I have heard the same noise on other falcons and commodores so my guess it is the common diff they share but that is just a guess.I was wondering if anyone on here has a more exact answer to what the noise is and if it is serious.Oh you I forgot to add it only happens at low speeds (IE 20 km and below). Edited 16/02/06 08:40 AM by snero3 Link to comment Share on other sites More sharing options...
FPV TRANNY Im the one and only Donating Members 3,557 Member For: 19y 11m 20d Gender: Male Location: In my house Posted 16/02/06 08:40 AM Share Posted 16/02/06 08:40 AM Welcome to the forum Is it more like a whine Link to comment Share on other sites More sharing options...
T007 Woooooooosh Donating Members 734 Member For: 19y 5m 20d Location: Sydney Posted 16/02/06 09:45 AM Share Posted 16/02/06 09:45 AM Sounds like the handbrake is rubbing Link to comment Share on other sites More sharing options...
snero3 Member 5 Member For: 19y 17d Posted 16/02/06 10:42 AM Author Share Posted 16/02/06 10:42 AM Welcome to the forum Is it more like a whine<{POST_SNAPBACK}>Hey thanks for that. Nah it is definately I "woosh woosh noise" it is not not a constant whine it is almost like something is rubbing back there. Link to comment Share on other sites More sharing options...
snero3 Member 5 Member For: 19y 17d Posted 16/02/06 10:45 AM Author Share Posted 16/02/06 10:45 AM Sounds like the handbrake is rubbing<{POST_SNAPBACK}>that would make sense but I am pretty sure I put the hand brake right down. Why would it be rubbing? Link to comment Share on other sites More sharing options...
T007 Woooooooosh Donating Members 734 Member For: 19y 5m 20d Location: Sydney Posted 16/02/06 10:48 AM Share Posted 16/02/06 10:48 AM Sounds like the handbrake is rubbingthat would make sense but I am pretty sure I put the hand brake right down. Why would it be rubbing?They get stuck all the time even when released very very common Link to comment Share on other sites More sharing options...
snero3 Member 5 Member For: 19y 17d Posted 16/02/06 10:57 AM Author Share Posted 16/02/06 10:57 AM Sounds like the handbrake is rubbing<{POST_SNAPBACK}>that would make sense but I am pretty sure I put the hand brake right down. Why would it be rubbing?<{POST_SNAPBACK}>They get stuck all the time even when released very very common<{POST_SNAPBACK}>Oh ok, so how do get ride of this? I can't imagine it is good for it. Link to comment Share on other sites More sharing options...
doublek Member 333 Member For: 20y 5m 27d Location: sydney Posted 16/02/06 10:12 PM Share Posted 16/02/06 10:12 PM when you get in the car to start it up, lift the handbrake lever up down about 3-4 times in rapid succession and this gets rid of it.hope this helps Link to comment Share on other sites More sharing options...
69FPV Member 48 Member For: 19y 11m 8d Posted 16/02/06 10:41 PM Share Posted 16/02/06 10:41 PM Sounds like the handbrake is rubbing<{POST_SNAPBACK}>that would make sense but I am pretty sure I put the hand brake right down. Why would it be rubbing?<{POST_SNAPBACK}>They get stuck all the time even when released very very common<{POST_SNAPBACK}>Oh ok, so how do get ride of this? I can't imagine it is good for it.<{POST_SNAPBACK}>It is also common that the rotors warp slightly (to say the standard ford brakes are sh*t, would be being very kind!), so as the rotor turns and passes through the caliper it will slightly touch, hence the brushing sound you here... I have had this also, it comes an goes. Can be annoying when driving slowly beside another car as you get the reverb... No biggy! Cheers Link to comment Share on other sites More sharing options...
benjam Member 137 Member For: 19y 8m 23d Location: Sydney NSW Posted 16/02/06 11:36 PM Share Posted 16/02/06 11:36 PM (edited) Sounds like the handbrake is rubbing<{POST_SNAPBACK}>that would make sense but I am pretty sure I put the hand brake right down. Why would it be rubbing?<{POST_SNAPBACK}>They get stuck all the time even when released very very common<{POST_SNAPBACK}>Oh ok, so how do get ride of this? I can't imagine it is good for it.<{POST_SNAPBACK}>It is also common that the rotors warp slightly (to say the standard ford brakes are sh*t, would be being very kind!), so as the rotor turns and passes through the caliper it will slightly touch, hence the brushing sound you here... I have had this also, it comes an goes. Can be annoying when driving slowly beside another car as you get the reverb... No biggy! Cheers<{POST_SNAPBACK}>Actually the handbrake is a separate part to the rear braking system. It is a small drum type brake behind each rear disc. I think it's the shoes that get out of alignment. I spoke to a Ford service manager about it once and he conceeded it was a design fault and affects both Fords and Holdens. Not even fixed in the BF apparantly! Check out this thread on how to adjust properly yourself if you feel the need. http://www.fordxr6turbo.com/forum/index.ph...54&hl=handbrakeI've have never bothered to do it myself but I've had the dealer check it a few times. I think they actually did it properly once too. It's easy to get rid of for awhile by lifting the handbrake at very slow speed, like 5 kph. Don't let the dealer charge you for "handbrake adjustment". You are entitled to have it fixed under warranty!! Ben Edited 16/02/06 11:41 PM by benjam Link to comment Share on other sites More sharing options...
