F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 1m 23d Gender: Male Location: Strapped in and holding on Posted 11/02/06 01:59 PM Share Posted 11/02/06 01:59 PM I hooked up a 4.8 0-60mph and 13.22 107mph in a stock typhoon with 1000km on the clock.<{POST_SNAPBACK}>cool. was it with a g-tech?? Link to comment Share on other sites More sharing options...
tur Flight 6 Member 471 Member For: 21y 6m 4d Posted 11/02/06 02:33 PM Share Posted 11/02/06 02:33 PM yep gtech timer Link to comment Share on other sites More sharing options...
rob82 Member 65 Member For: 19y 2m 19d Posted 12/02/06 10:05 AM Share Posted 12/02/06 10:05 AM I had the priviledge of tuning a BF Tornado 6-speed auto ute from one of the Perth forum members yesterday, with Barry from BPT Motorsport in attendance as well.The ute had approximately 400km's on the odo and put down a baseline of 225rwkw in stock trim. With the addition of bigger injectors, bigger dump pipe, twin cats and a cat back system and a retune it now pumps out a healthy 297.5rwkw It makes a calculated 750nm at the flywheel now, with the stock power output showing bang on 550nm.On the road the ute went like a cut snake, until a hose from the turbo blew off. That was soon rectified. The power delivery with the auto is truly phenominal, and doesn't stop pulling. I'd say a 6-speed manual with the same power, or even a little more, would have a hard job keeping up with the auto - from a standing start or on the roll.Graph is attached.Greg, I'm jealous now and want one Ben, you'll have no chance now <{POST_SNAPBACK}>Looks like a fixed dyno duty cycle by the look of that torque curve. Have you got one of boost? Link to comment Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 20y 1m 3d Location: Perth Posted 12/02/06 10:23 AM Author Share Posted 12/02/06 10:23 AM I had the priviledge of tuning a BF Tornado 6-speed auto ute from one of the Perth forum members yesterday, with Barry from BPT Motorsport in attendance as well.The ute had approximately 400km's on the odo and put down a baseline of 225rwkw in stock trim. With the addition of bigger injectors, bigger dump pipe, twin cats and a cat back system and a retune it now pumps out a healthy 297.5rwkw It makes a calculated 750nm at the flywheel now, with the stock power output showing bang on 550nm.On the road the ute went like a cut snake, until a hose from the turbo blew off. That was soon rectified. The power delivery with the auto is truly phenominal, and doesn't stop pulling. I'd say a 6-speed manual with the same power, or even a little more, would have a hard job keeping up with the auto - from a standing start or on the roll.Graph is attached.Greg, I'm jealous now and want one Ben, you'll have no chance now <{POST_SNAPBACK}>Looks like a fixed dyno duty cycle by the look of that torque curve. Have you got one of boost?<{POST_SNAPBACK}>Negative, I don't tune like that. The actuator assembly will not hold more than 13psi boost at peak rpm.Affirmative, there is one of boost - it follows the same line at the torque curve. Link to comment Share on other sites More sharing options...
rob82 Member 65 Member For: 19y 2m 19d Posted 12/02/06 11:21 AM Share Posted 12/02/06 11:21 AM Negative, I don't tune like that. The actuator assembly will not hold more than 13psi boost at peak rpm.Why is that? Link to comment Share on other sites More sharing options...
