  • Seriously Flukey Member
  • Member For: 21y 2m 25d
  MacVibe said:
Hey guys,
I know there are heaps of threads on mods and performance gains, however if I was to get a full exhaust, new intercooler and air filter (either BMC or K&N) on a stock auto XR6T, could I expect gains of 15%?
Thanks
Easier than that. Go and spend $1500 on a custom tuned Edit and you'll gain 25%.
Cooler and exhaust can come later.
In fact, if you dont do Edit first, all you will get is overboost and your car will run like :stirthepot:
https://www.fordxr6turbo.com/forum/topic/23124-power-gains/#findComment-344102
  • 3 years later...
  • New Member
  • Member For: 15y 9m 12d
  On 03/02/2006 at 11:08 AM, MacVibe said:
Hey guys,
Thanks
yeh mate go for it, these mods are good stepping stones. 15% I dont know but 15 kw yes.
https://www.fordxr6turbo.com/forum/topic/23124-power-gains/#findComment-931859
  • Member For: 17y 9m 4d
save your pennies, buy the following parts first:
- injectors
- flash tuner
- intercooler
- valve springs
- fuel pump
then get a custom tune with all these parts fitted at the same time. you'll be able to run 12psi and push out around 260 - 300rwkw depending on if your car's an auto/manual etc.
then save for a proper full exhaust system, turbo modification (wastegate/actuator), surge tank and a re-tune. Then you'll be looking at 300-350rwkw.
don't do it any other way.
https://www.fordxr6turbo.com/forum/topic/23124-power-gains/#findComment-931918
