BLN68U Member 43 Member For: 19y 8m 14d Posted 03/02/06 09:49 AM Share Posted 03/02/06 09:49 AM after installing capa box I have had the car rev higher on start up almost every time and it seems to be getting hotter quicker but not on temp gauge just feeling it outside the car, the reving on start up goes up 2 1200rpm then very slowly comes back down, anybody else have the same experience! Link to comment https://www.fordxr6turbo.com/forum/topic/23122-high-idle-onstart-up-after-cappa-edit/ Share on other sites More sharing options...
Guest Guests Posted 03/02/06 09:53 AM Share Posted 03/02/06 09:53 AM Yea,mine does that...vik... but drops down fairly qiuck,30 40 seconds ??? I reckon Link to comment https://www.fordxr6turbo.com/forum/topic/23122-high-idle-onstart-up-after-cappa-edit/#findComment-344070 Share on other sites More sharing options...
JimmyXR6T04 Member 1,299 Member For: 19y 10m 13d Location: Canberra Posted 03/02/06 10:06 AM Share Posted 03/02/06 10:06 AM mine does this with edit, and standard tunes. I think a lot of people have the same situation. Mine revs to around 1800rpm then drops very quickly, say around 2 seconds. On one instance it revved to 2000rpm and stayed there for around 25 seconds, before I shut the car off and restarted... all was good then. As for the heat, I notice that in standard form, the temp gauge always gets closer to the middle. However, when I have my tune in, the temp stays a bit under half way between 1/4 and 1/2. Which is always a good thing!! I think its has something to do with how it was tuned. Either way, it can only be a good thing if the car isn't getting as hot! Link to comment https://www.fordxr6turbo.com/forum/topic/23122-high-idle-onstart-up-after-cappa-edit/#findComment-344075 Share on other sites More sharing options...
LTSBGY Member 259 Member For: 19y 3m 16d Posted 03/02/06 10:09 AM Share Posted 03/02/06 10:09 AM I dont know how it works with the fords but I know that my mates nissan maxima goes to bout 2000rpm on start up to get the oil running in engine quicker then drops. The engines in the maxima are the 300sx engines just non turbo. Could it be also be the case with the XR6T's that its trying to get the oil circulating quicker?Nesh Link to comment https://www.fordxr6turbo.com/forum/topic/23122-high-idle-onstart-up-after-cappa-edit/#findComment-344077 Share on other sites More sharing options...
bloosted Cruise Control 1,383 Member For: 19y 4m 27d Gender: Male Location: Adelaide Posted 03/02/06 10:10 AM Share Posted 03/02/06 10:10 AM yep mine used to do it but I mentioned it to my tuner and he fixed itI think the latest software has it sorted along with a lot of other stuff ietraction control giving up Link to comment https://www.fordxr6turbo.com/forum/topic/23122-high-idle-onstart-up-after-cappa-edit/#findComment-344078 Share on other sites More sharing options...
dingah2 Crusty aviator Member 846 Member For: 20y 10m 14d Gender: Male Location: ACT Posted 03/02/06 10:38 AM Share Posted 03/02/06 10:38 AM My expeience the same as bloosted. Initially appeared to be one of the various installed 'features' of the initial tune along with the disappearing TC which was subsequently sorted by a better/correct tune.Dingah Link to comment https://www.fordxr6turbo.com/forum/topic/23122-high-idle-onstart-up-after-cappa-edit/#findComment-344088 Share on other sites More sharing options...
sutty Mushroom Donating Members 799 Member For: 20y 11m 18d Gender: Male Location: THORNLANDS, QLD Posted 03/02/06 10:54 AM Share Posted 03/02/06 10:54 AM Mine shoots up to over 2000, but drops fairly quickly. Going back soon to hopefully get it sorted. The biggest problem with this is that the tuner only gets 1 chance to see what's happening.I also have the TC problem, but hopefully that will get sorted too. Link to comment https://www.fordxr6turbo.com/forum/topic/23122-high-idle-onstart-up-after-cappa-edit/#findComment-344094 Share on other sites More sharing options...
Paranormal Member 469 Member For: 21y 8m 9d Location: Brissy Posted 03/02/06 10:58 AM Share Posted 03/02/06 10:58 AM Well feck my generic tune has done that every day since just reciving a new capa flash tuner only 3 weeks ago, goes up to 1000-1200 and have to wait bout 4-5 seconds for reves to come down before dropping her into gear. Also had the TC disenage on the first day but it was wet, been ok since on that front.How can you tell what tune revision is in your box?Whats the latest and whats involved in geting any flash upgrades?Either way I'm happy as pig in Sh1T looking for more more more already, and will be going custom tune real soon once cat and inj get here so probably a mute post. Link to comment https://www.fordxr6turbo.com/forum/topic/23122-high-idle-onstart-up-after-cappa-edit/#findComment-344097 Share on other sites More sharing options...
F6 RAPID Formerly Turbo6 Donating Members 2,332 Member For: 22y 3m 25d Location: North Brisbane Posted 03/02/06 11:26 AM Share Posted 03/02/06 11:26 AM Mate, get your tuner to fix it. Mine did it, Simon found out, he fixed it. Link to comment https://www.fordxr6turbo.com/forum/topic/23122-high-idle-onstart-up-after-cappa-edit/#findComment-344107 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 7d Gender: Male Location: Victoria Posted 04/02/06 12:12 AM Share Posted 04/02/06 12:12 AM Yes it can be adjusted. Link to comment https://www.fordxr6turbo.com/forum/topic/23122-high-idle-onstart-up-after-cappa-edit/#findComment-344253 Share on other sites More sharing options...
