BLN68U Member 43 Member For: 19y 5m 21d Posted 29/01/06 01:12 AM Share Posted 29/01/06 01:12 AM Anyone had this happen before or know what or why it has happened?After a 25min drive I stopped my xr6t saw someone for 10min then got back into it and as I started up it blew out a huge white cloud of smoke I drove down the road and smoke got less and as I let it idle it gradually went anyone no what it is the car is all stock but 1800ks overdue for a service. thanks Link to comment Share on other sites More sharing options...
shockF6 Member 478 Member For: 19y 4m 4d Location: Melbourne Posted 29/01/06 01:25 AM Share Posted 29/01/06 01:25 AM IMO 15000 k's is too long between oil changes. if you have now gone longer than that I would get it done ASAP regardless of if it caused your problem Link to comment Share on other sites More sharing options...
xlr8ed Phantom lives Member 1,417 Member For: 20y 9m 18d Gender: Male Location: who knows Posted 29/01/06 01:25 AM Share Posted 29/01/06 01:25 AM Sounds like the seals in the turbo are starting to leak oil.... If you want to check it pull the intake pipe off the front of the turbo and see how much oil is sitting in the pipe or dripping out the front housing in the turbo... Best to do this in morning cold....jeff Link to comment Share on other sites More sharing options...
Jake F6 Donating Members 327 Member For: 21y 6m 25d Location: Melbourne Posted 03/03/08 08:47 AM Share Posted 03/03/08 08:47 AM Apparently my car was blowing a few puffs of white smoke here and there on a recent cruise. It had an oil change done the week earlier. There is some oil in the air intake tube (before the plenum)Other members tell me that oil in this tube is fairly normal..Should I be worried?Is there anything that can be done to stop the seals on the turbo leaking oil?Jake. Link to comment Share on other sites More sharing options...
cplagz Member 19 Member For: 17y 15d Posted 04/03/08 01:31 AM Share Posted 04/03/08 01:31 AM Apparently my car was blowing a few puffs of white smoke here and there on a recent cruise. It had an oil change done the week earlier. There is some oil in the air intake tube (before the plenum)Other members tell me that oil in this tube is fairly normal..Should I be worried?Is there anything that can be done to stop the seals on the turbo leaking oil?Jake.Replace the seals. Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 1d Gender: Male Location: SW Sydney Posted 04/03/08 02:47 AM Share Posted 04/03/08 02:47 AM a little bit is normal, but if there is enough to make it drip out easily, you will need new seals Link to comment Share on other sites More sharing options...
JETFPV Donating Members 672 Member For: 17y 3m 3d Gender: Male Posted 04/03/08 02:56 AM Share Posted 04/03/08 02:56 AM Definately sounds like the turbocharger seal is slowly seeping oil into the exhaust housing.I would be getting it looked at if it continues to get worse. Link to comment Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 5m 3d Gender: Male Location: Southern Highlands NSW Posted 04/03/08 03:28 AM Share Posted 04/03/08 03:28 AM Its ok. Mine did the same thing around 4 months ago and it hasnt done it since. I managed to get video of it. It only happened after I washed the car drove it for a while then pulled up in the driveway. The turbo seals are fine as I had ford check them outCant up load the vid for some reason Link to comment Share on other sites More sharing options...
