Street Tuner Member 727 Member For: 21y 10m 20d Posted 30/01/06 04:04 AM Share Posted 30/01/06 04:04 AM (edited) I've set mine to .89mm & they still miss, just not as bad so at least .8mm.Russ<{POST_SNAPBACK}>Check the plug gap?Sounds like Im not the only one? Edited 30/01/06 04:09 AM by Street Tuner Link to comment Share on other sites More sharing options...
pumped81 Member 49 Member For: 20y 1m 6d Location: Tassie Posted 30/01/06 05:15 AM Author Share Posted 30/01/06 05:15 AM I spoke to the guys at CAPA today. I have sent my box back to have the new tunes loaded onto it, hopefully this will solve the problem.Does anyone have any info on the new CAPA direct replacement intercooler? It just has it listed on the site with a price. They are $795, but there are no pictures or specs.. Link to comment Share on other sites More sharing options...
dingah2 Crusty aviator Member 846 Member For: 20y 4m 25d Gender: Male Location: ACT Posted 30/01/06 07:46 AM Share Posted 30/01/06 07:46 AM Guys, a correctly set up Edit will not disable the TC; however, a correctly set up Edit may require a custom tune from someone of a worthy capability and reputation. That same person could also check out your electrics at the same time removing the guesswork and conjecture out of the debate; there are several things that can manifest in the way described in this thread and plug gapping may or may not be the answer. Your Edit and PCM tunes may be digital but the rest of car isn't.Dingah Link to comment Share on other sites More sharing options...
thebrunks Member 665 Member For: 20y 4m 3d Location: Gold Coast Posted 30/01/06 08:27 AM Share Posted 30/01/06 08:27 AM Check the plug gap?Sounds like Im not the only one?So you reckon .8mm is too close????ROFL Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 6m 18d Gender: Male Location: Victoria Posted 30/01/06 08:29 AM Share Posted 30/01/06 08:29 AM My plugs are gapped to .89mm and no problems whatsoever. Link to comment Share on other sites More sharing options...
thebrunks Member 665 Member For: 20y 4m 3d Location: Gold Coast Posted 30/01/06 08:33 AM Share Posted 30/01/06 08:33 AM down to .89mm did make a huge difference, but I still get them going out on the 10PSI tune, just not as severe.They'll definately need to go closer to solve the issue. Link to comment Share on other sites More sharing options...
igsta Member 371 Member For: 21y 1m 4d Gender: Male Location: Sydney Posted 30/01/06 09:24 AM Share Posted 30/01/06 09:24 AM I had the same prob. Re-gaped the plugs and it was still doing it. Got a custom tune with even more boost and problem fixed. Link to comment Share on other sites More sharing options...
