Hi Flow "cats"
hrb93
  • Phantom lives
  • Member For: 20y 9m 23d
This current Cat discussion and those that have gone before have been very subjective in that there does not appear to be any valid information, apart from the usual glossys, that provide sufficient information for the likes of this forum to make an informed decision on which Cats are best suited to the XR6T.
I have the 3" 'Metal' Cat and whilst it is an improvement in terms of rwkw on the factory unit , I would not want to get into a pissing match to say which is the best Cat with out the technical info (test data ) to back up my argument.
If there is info out there then I would like to see it.
<{POST_SNAPBACK}>
As I said earlier I have these on mine I gained 18rwhp then tuned over 60hp at the tyres when I changed to twin cats and dump and exhaust..My exhaust guru put one of these on a flow bench and it flowed close to 750cfm..
I run up to 26psi of boost through them and run 536hp at the wheels this is proven.. I know people trust what I say on here, you dont have to if you want..
http://www.fordxr6turbo.com/forum/index.ph...topic=15748&hl=
This link will show you
jeff
<{POST_SNAPBACK}>
If I just wanted to upgrade the CAT due to financial constraints what size should I be going for ? 3, 3.5 or 4 inch? Do all three cost the same? I have been quoted $350 for a 3.5 inch Metal CAT. Do you think we can get the same group price as the rotary boys ?
<{POST_SNAPBACK}>
If you want to run over 13psi boost I would save your money and get the dump pipe done with a 4 inch cat and if you dont then just go to a 3.5 highflow cat of your choice but I do recomend the magic cats.... I also run NOS through these cats aswell with no hiccups..
jeff
  • Replies 49
  • Seriously Flukey Member
  • Member For: 20y 10m 23d
jeff
jeff
I need a new ( read higher flow ) Cat but my car scrapes already :spit:
I imagine changing the Cat will make it worse.
  • Member For: 20y 7m 3d
I pinched this from another forum
Here are some facts on Metallic Substrate Catalytic Converters:
Metallic Substrates are superior to traditional Ceramic Substrates which have been used by the previous "name brands" of high flow catalytic converters. This is because the walls of the substrate are thinner, allowing greater flow.
MAGIC Metallic Substrate Catalytic Converters flow up to 50% more than their traditional competitors. Fitting a MAGIC Cat has been shown to increase power by up to 40HP at the wheels.
Catalytic Converter substrates are coated with material which produces changes in the gases which pass over them. The more cells per square inch the more effective is the catalytic process because there is more surface area.
Magic Cats are constructed with a 300 cell per square inch metallic substrate, and 304 stainless steel body.
Any catalytic converter which is not a direct fit replacement for the original will need modification to fit a vehicle's exhaust, or the exhaust modified to fit the cat.
MAGIC is a registered trademark.
Magic Performance is an Australian business
Our Australian Business Number (ABN) is 18097792437
We have street front address which is 25 Carter Road, Brookvale, NSW 2100
We have a workshop with a NSW Vehicle Repairer's License
We can fit any product we sell or advise your prefered fitter on correct procedures.
Magic Cats have been independently flow tested against major competitors products.
Magic Performance provide a range of products to fit 3 inch, 3 1/2 inch and 4 inch exhausts.
Magic Performance is the only supplier of Metallic Substrate Catalytic Converters in Australia with inlet and outlet of four inches.
If you have any questions about extreme flow catalytic converters, phone Magic Performance on 02 99391644 or post here. We actually know what we are doing, not just selling the product. yes.gif
Cheers,
The team at MAGIC PERFORMANCE
  • Phantom lives
Can someone just tell me what the buy price is for a group buy cause there is no way im logging on to that site to see the info...
I will get a trade price for you all A.S.A.P
jeff
  • Member For: 19y 11m 20d
jeff
<{POST_SNAPBACK}>
I'm interested, I would like to get them to fit it as well.
  • Member For: 21y 12d
jeff
im interested.... can FIST fit these as well... and can FIST do my 15000km service??
knowing how you guys work... I am guessing yes to the above questions??
When I got mine from the Nissan Silvia GB, I paid $210 I think delivered for the 4" version.
The ausrotor GB is for $230 delivered.
<{POST_SNAPBACK}>
I just called them up and they can do them for $200 inc GST plus freight
They are also an exhaust shop so if you need to get them fitted and live in Sydney they can help out.
So can we organise a group buy ?
