Terebro Member 170 Member For: 19y 9m 23d Posted 21/01/06 05:09 AM Share Posted 21/01/06 05:09 AM Did you bolt your magic cat to a stock dump & exhaust system?Measure the improvements? Link to comment Share on other sites More sharing options...
FR33DY Member 307 Member For: 19y 11m 20d Gender: Male Location: Sydney Posted 21/01/06 06:38 AM Share Posted 21/01/06 06:38 AM Yeah, I think they are in Brookvale/North Shore.On the picture in the thread on Ausrotor, ring the telephine number on the "CAT".It cost me $250 installed. The other brand name American ones I had were $500 installed and were sh*t.<{POST_SNAPBACK}>I will give them a call on monday and find out more, I would rather they fit it then me trying to explain to a exhaust shop what I need, should be a nice addtion to my DW cooler Link to comment Share on other sites More sharing options...
galconn Member 101 Member For: 19y 5m 23d Posted 21/01/06 08:36 AM Share Posted 21/01/06 08:36 AM This current Cat discussion and those that have gone before have been very subjective in that there does not appear to be any valid information, apart from the usual glossys, that provide sufficient information for the likes of this forum to make an informed decision on which Cats are best suited to the XR6T. I have the 3" 'Metal' Cat and whilst it is an improvement in terms of rwkw on the factory unit , I would not want to get into a pissing match to say which is the best Cat with out the technical info (test data ) to back up my argument. If there is info out there then I would like to see it. Link to comment Share on other sites More sharing options...
hrb93 Member 84 Member For: 19y 1m 2d Posted 21/01/06 12:13 PM Author Share Posted 21/01/06 12:13 PM http://ausrotary.dntinternet.com/forums/vi...light=magic+catMetal flows 534, Magic 754cfm Link to comment Share on other sites More sharing options...
FR33DY Member 307 Member For: 19y 11m 20d Gender: Male Location: Sydney Posted 21/01/06 12:24 PM Share Posted 21/01/06 12:24 PM http://ausrotary.dntinternet.com/forums/vi...light=magic+catMetal flows 534, Magic 754cfm<{POST_SNAPBACK}>Just had a read of the other forum, its seems to work well for them, might be a good investment for some cheap power gain, cant afford a SMB dump pipe and 4 inch cat, this might be my plan B. The contact number off the CAT is Magic CAT 02 99391644 Link to comment Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 22y 2m 30d Gender: Male Location: Dé·jà vu Posted 21/01/06 12:27 PM Share Posted 21/01/06 12:27 PM Just a not hrb93, you need to be a member of Ausrotary to view the links your posting...not sure if your aware or not....Not that it takes much to join... Link to comment Share on other sites More sharing options...
hrb93 Member 84 Member For: 19y 1m 2d Posted 21/01/06 01:45 PM Author Share Posted 21/01/06 01:45 PM I assumed everyone would be a member, love the rotors. Link to comment Share on other sites More sharing options...
xlr8ed Phantom lives Member 1,417 Member For: 20y 9m 23d Gender: Male Location: who knows Posted 21/01/06 09:17 PM Share Posted 21/01/06 09:17 PM This current Cat discussion and those that have gone before have been very subjective in that there does not appear to be any valid information, apart from the usual glossys, that provide sufficient information for the likes of this forum to make an informed decision on which Cats are best suited to the XR6T. I have the 3" 'Metal' Cat and whilst it is an improvement in terms of rwkw on the factory unit , I would not want to get into a pissing match to say which is the best Cat with out the technical info (test data ) to back up my argument. If there is info out there then I would like to see it.<{POST_SNAPBACK}>As I said earlier I have these on mine I gained 18rwhp then tuned over 60hp at the tyres when I changed to twin cats and dump and exhaust..My exhaust guru put one of these on a flow bench and it flowed close to 750cfm..I run up to 26psi of boost through them and run 536hp at the wheels this is proven.. I know people trust what I say on here, you dont have to if you want..http://www.fordxr6turbo.com/forum/index.ph...topic=15748&hl=This link will show youjeff Link to comment Share on other sites More sharing options...
Falchoon I see red Member 5,758 Member For: 22y 1m 28d Location: nowhere in particular Posted 21/01/06 09:56 PM Share Posted 21/01/06 09:56 PM Just a not hrb93, you need to be a member of Ausrotary to view the links your posting...not sure if your aware or not....Not that it takes much to join...<{POST_SNAPBACK}>And Hotmail email addresses are not accepted either... Link to comment Share on other sites More sharing options...
FR33DY Member 307 Member For: 19y 11m 20d Gender: Male Location: Sydney Posted 21/01/06 10:23 PM Share Posted 21/01/06 10:23 PM This current Cat discussion and those that have gone before have been very subjective in that there does not appear to be any valid information, apart from the usual glossys, that provide sufficient information for the likes of this forum to make an informed decision on which Cats are best suited to the XR6T. I have the 3" 'Metal' Cat and whilst it is an improvement in terms of rwkw on the factory unit , I would not want to get into a pissing match to say which is the best Cat with out the technical info (test data ) to back up my argument. If there is info out there then I would like to see it.<{POST_SNAPBACK}>As I said earlier I have these on mine I gained 18rwhp then tuned over 60hp at the tyres when I changed to twin cats and dump and exhaust..My exhaust guru put one of these on a flow bench and it flowed close to 750cfm..I run up to 26psi of boost through them and run 536hp at the wheels this is proven.. I know people trust what I say on here, you dont have to if you want..http://www.fordxr6turbo.com/forum/index.ph...topic=15748&hl=This link will show youjeff<{POST_SNAPBACK}>If I just wanted to upgrade the CAT due to financial constraints what size should I be going for ? 3, 3.5 or 4 inch? Do all three cost the same? I have been quoted $350 for a 3.5 inch Metal CAT. Do you think we can get the same group price as the rotary boys ? Link to comment Share on other sites More sharing options...
