Boost!
ford number 1
  • Member For: 20y 5m 3d
If it is boost leak would I hear anything different when I have the higher psi maps in or will it sound same as standard??
Hopefully its an easy fix when custom tune is done on 31st...
  • Member For: 20y 4m 17d
I just installed a boost gauge in my car today and went for a drive with 8psi map.The boost peaked at 5psi but was mainly around 4psi.I pulled over and loaded in the 10psi map and the boost was exactly the same..
Ive had the edit for just over a month and I have never been overly impressed with it.Now I know why..
I will connect my boost gauge to a mates car tomorrow just to make sure!!
Any ideas of what the problem could be..Not  :censored: happy Jan..
<{POST_SNAPBACK}>
Sound about right for a blown of intake hose, if its under the headlight, it will hold about 4 psi maybe 5, not much more, drives normal raound town, but wont go up top.
Use some hairspay when you put them back on, it helps them slide on and dries as sticky as chewy gum, get rid of the crap spring clips and buy some decent stainless hose clamps.
See you Sunday.
  • Team Xtreme
  • Member For: 19y 11m 24d
Can anyone say boost leak?
That will be it. Either off the compressor outlet, or at the throttle body. One or the other....
boost leak or waste gate fault im with martin on that one
  • Member For: 20y 3m 3d
My original 8 and 10 psi CAPA tunes wouldn't go above 5psi either with the 10 psi showing particularly ugly lines on a dyno graph. I assumed it was wastegate not allowing boost to climb as it wasn't leaking boost. After seeing the graph, Street Tuner kindly emailed the latest updates (tunes) to the place where I purchased the flasher from and its very much improved.
Of course, a custom tune will fix it, but the latest CAPA tunes probably will as well.
Mark
  • Just because it is, doesn't mean it should be.....
  • Member For: 20y 4m 20d
  • Gender: Female
Its Phantom.Bought from Act last November.If it had a chip in ti before hand and was taken out why would this affect the edit from working??
<{POST_SNAPBACK}>
well colour is definately not the problem then :smilielol:
shazzy
