sutty Mushroom Donating Members 799 Member For: 20y 11m 22d Gender: Male Location: THORNLANDS, QLD Posted 29/01/06 08:15 AM Share Posted 29/01/06 08:15 AM Street Tuner said: sutty said: Every time I put the boot in enough for TC to engage for longer than a couple of 10ths of a second, the TC turns off. So it's generally off after the first set of lights.One would hazard a guess that the settings are not right in your program then Care to elaborate?? Link to comment https://www.fordxr6turbo.com/forum/topic/22722-on-full-boost-engine-drops-power-rough-idle/page/4/#findComment-341587 Share on other sites More sharing options...
Street Tuner Member 727 Member For: 22y 4m 13d Posted 29/01/06 09:26 AM Share Posted 29/01/06 09:26 AM Ive posted this a few times before, but in short....The 'Torque Module Switch' is turned offor the 'Minimum Engine Torque Allowed' settings have been modified. Link to comment https://www.fordxr6turbo.com/forum/topic/22722-on-full-boost-engine-drops-power-rough-idle/page/4/#findComment-341604 Share on other sites More sharing options...
xlr8ed Phantom lives Member 1,417 Member For: 21y 16d Gender: Male Location: who knows Posted 29/01/06 10:22 AM Share Posted 29/01/06 10:22 AM Street Tuner said: Ive posted this a few times before, but in short....The 'Torque Module Switch' is turned offor the 'Minimum Engine Torque Allowed' settings have been modified.<{POST_SNAPBACK}>Great info supplied there Tuner we will look at that when your back in PhilGlad you posted it again for us as we all dont get to read every post that's written...jeff Link to comment https://www.fordxr6turbo.com/forum/topic/22722-on-full-boost-engine-drops-power-rough-idle/page/4/#findComment-341629 Share on other sites More sharing options...
CountryPhoon Member 180 Member For: 19y 10m 25d Posted 29/01/06 10:48 PM Share Posted 29/01/06 10:48 PM So what is it that creates the Traction Control problems - simply excessive torque?If so, what is the limit on torque before the TC problem emerges? Here in snow and ice country (in Winter at least), having the TC operational is a must... (Not going to bother with edit on my manual Ba, but Bf F6 Auto is coming in March...)<{POST_SNAPBACK}>Can any of the experts out there help me with this specific enquiry???Thanks. Link to comment https://www.fordxr6turbo.com/forum/topic/22722-on-full-boost-engine-drops-power-rough-idle/page/4/#findComment-341801 Share on other sites More sharing options...
sutty Mushroom Donating Members 799 Member For: 20y 11m 22d Gender: Male Location: THORNLANDS, QLD Posted 30/01/06 02:00 AM Share Posted 30/01/06 02:00 AM Street Tuner said: Ive posted this a few times before, but in short....The 'Torque Module Switch' is turned offor the 'Minimum Engine Torque Allowed' settings have been modified.Are these the options to modify "torque tags" or is that a different kettle of fish altogether? Link to comment https://www.fordxr6turbo.com/forum/topic/22722-on-full-boost-engine-drops-power-rough-idle/page/4/#findComment-341873 Share on other sites More sharing options...
Street Tuner Member 727 Member For: 22y 4m 13d Posted 30/01/06 02:08 AM Share Posted 30/01/06 02:08 AM CountryPhoon if neither of those two settings have been changed then your traction control should remain operative under all conditions. Link to comment https://www.fordxr6turbo.com/forum/topic/22722-on-full-boost-engine-drops-power-rough-idle/page/4/#findComment-341883 Share on other sites More sharing options...
sport Member 62 Member For: 22y 17d Posted 11/02/06 09:41 PM Share Posted 11/02/06 09:41 PM At high RPM / boost with stock exhaust, back pressure holds the valves open hence creating extra distance bteween the valve and lifter which then pump up hydraulically and when you come back to idle with a pumped up lifter, the lifter holds the valves open and causes the engine to idle roughly for a short time until the lifters pump down agian and allow the valves to fully close. A higher flow exhaust sytem will reduce the back pressure which will eliminate the problem or you can get someone like Nispro to fit heavier valve springs which will achieve the same result certainly upto a 10psi map but will have the added benifit of allowing you to maintain a stock apperance if you have concerns about your dealer or insurance. Link to comment https://www.fordxr6turbo.com/forum/topic/22722-on-full-boost-engine-drops-power-rough-idle/page/4/#findComment-347462 Share on other sites More sharing options...
