xlr8ed Phantom lives Member 1,417 Member For: 20y 9m 30d Gender: Male Location: who knows Posted 28/01/06 12:31 PM Share Posted 28/01/06 12:31 PM brunks sounds like u might have vavle spring issuesMate could be, does it seem as though the PCM shut's down to protect itself?The traction control light coming on was a bit strange!Russ<{POST_SNAPBACK}>Same thing was happening to Sutty and we changed valve springs in his car today and fixed the problem he already had new v8 valve springs in his but we put the nizpro springs in and gained 20kw at the tyres at 5500rpm and lost the flutter..Even new valve springs can fail after short periods or instantly..He also has the traction control problem but will have to chack with him if its now fixed..We tried the latest edit program and we can run the cars over 40kph .. Have to get on to C.A.P.A about that....Any ideas TUNER?....jeff Link to comment Share on other sites More sharing options...
sutty Mushroom Donating Members 799 Member For: 20y 9m 6d Gender: Male Location: THORNLANDS, QLD Posted 28/01/06 12:39 PM Share Posted 28/01/06 12:39 PM brunks sounds like u might have vavle spring issuesMate could be, does it seem as though the PCM shut's down to protect itself?The traction control light coming on was a bit strange!RussSame thing was happening to Sutty and we changed valve springs in his car today and fixed the problem he already had new v8 valve springs in his but we put the nizpro springs in and gained 20kw at the tyres at 5500rpm and lost the flutter..Even new valve springs can fail after short periods or instantly..He also has the traction control problem but will have to chack with him if its now fixed..We tried the latest edit program and we can run the cars over 40kph .. Have to get on to C.A.P.A about that....Any ideas TUNER?....jeffEnd result was a 44 rwkw gain and a nice smooth curve again.Traction control problem still there (no dramas in the dry, as I normally turn it off anyways, but very "interesting" in the wet!). Link to comment Share on other sites More sharing options...
CountryPhoon Member 180 Member For: 19y 8m 9d Posted 28/01/06 09:21 PM Share Posted 28/01/06 09:21 PM End result was a 44 rwkw gain and a nice smooth curve again.Traction control problem still there (no dramas in the dry, as I normally turn it off anyways, but very "interesting" in the wet!).So what is it that creates the Traction Control problems - simply excessive torque?If so, what is the limit on torque before the TC problem emerges? Here in snow and ice country (in Winter at least), having the TC operational is a must... (Not going to bother with edit on my manual Ba, but Bf F6 Auto is coming in March...) Link to comment Share on other sites More sharing options...
xlr8ed Phantom lives Member 1,417 Member For: 20y 9m 30d Gender: Male Location: who knows Posted 28/01/06 09:23 PM Share Posted 28/01/06 09:23 PM Just use that tractor instead....LOLjeff Link to comment Share on other sites More sharing options...
CountryPhoon Member 180 Member For: 19y 8m 9d Posted 28/01/06 09:27 PM Share Posted 28/01/06 09:27 PM Just use that tractor instead....LOLjeff<{POST_SNAPBACK}>Good point! Don't need TC on that big sucker; has AWD!! Link to comment Share on other sites More sharing options...
sutty Mushroom Donating Members 799 Member For: 20y 9m 6d Gender: Male Location: THORNLANDS, QLD Posted 28/01/06 10:44 PM Share Posted 28/01/06 10:44 PM End result was a 44 rwkw gain and a nice smooth curve again.Traction control problem still there (no dramas in the dry, as I normally turn it off anyways, but very "interesting" in the wet!).So what is it that creates the Traction Control problems - simply excessive torque?If so, what is the limit on torque before the TC problem emerges? Here in snow and ice country (in Winter at least), having the TC operational is a must... (Not going to bother with edit on my manual Ba, but Bf F6 Auto is coming in March...)Every time I put the boot in enough for TC to engage for longer than a couple of 10ths of a second, the TC turns off. So it's generally off after the first set of lights. Link to comment Share on other sites More sharing options...
Street Tuner Member 727 Member For: 22y 1m 28d Posted 28/01/06 11:06 PM Share Posted 28/01/06 11:06 PM Every time I put the boot in enough for TC to engage for longer than a couple of 10ths of a second, the TC turns off. So it's generally off after the first set of lights.<{POST_SNAPBACK}>One would hazard a guess that the settings are not right in your program then Link to comment Share on other sites More sharing options...
Street Tuner Member 727 Member For: 22y 1m 28d Posted 28/01/06 11:07 PM Share Posted 28/01/06 11:07 PM We tried the latest edit program and we can run the cars over 40kph .. Have to get on to C.A.P.A about that....Any ideas TUNER?....jeff<{POST_SNAPBACK}>Errr....English please?What is the actual problem? Im just a little confused as your text doesnt contain much detail Link to comment Share on other sites More sharing options...
xlr8ed Phantom lives Member 1,417 Member For: 20y 9m 30d Gender: Male Location: who knows Posted 29/01/06 12:38 AM Share Posted 29/01/06 12:38 AM We tried the latest edit program and we can run the cars over 40kph .. Have to get on to C.A.P.A about that....Any ideas TUNER?....jeff<{POST_SNAPBACK}>Errr....English please?What is the actual problem? Im just a little confused as your text doesnt contain much detail <{POST_SNAPBACK}>Sorry, with the new update in the cars they go straight into limp mode as soon as they get to 40kph (flashing D on dash)..jeff Link to comment Share on other sites More sharing options...
Street Tuner Member 727 Member For: 22y 1m 28d Posted 29/01/06 02:49 AM Share Posted 29/01/06 02:49 AM (edited) This is the first report of any problem with the basic tunes we supply dealers, and there are plenty out there using them. However they are just that a 'base'. I would suggest that you may possible be trying to put the wrong processor code in the incorrect vehicle and causing some kind of transmission mismatch.The simple answer to this is to physically read the processor code off the side of the factory PCM and create a new program - using the correct processor code - incorporating all of the changes in the supplied file. This should take around 5 mintues, and give you a definitive answer. Edited 29/01/06 02:50 AM by Street Tuner Link to comment Share on other sites More sharing options...
