  • Member For: 20y 27d
Well then why was my car left like it and also Mikka's (on the first visit)?
Might have to send my box down for adjustment.
EDIT: Not the clicking solenoid but the boost flunctuation.
Edited by 2fardown
  • Replies 32
Posted Images
  • Member For: 19y 6m 16d
  2fardown said:
I'm having the same problem with dynowog tune and another custom tune.  It's really giving me the sh!ts.
What would happen if I was to fit an aftermarket electronic boost controller?  Would this hold the boost more effectively?
Also you're complaing about only having 250rwkw but you're only running 8psi?  Was that because it was pinging / detonating?  Surely the tuner could have squizzed at least 10psi into it.
<{POST_SNAPBACK}>
no it wasnt pinging or detonating, my tuner says that apparently the exaust can't handle more boost. wtf? :spoton:
I also thought 10 psi was resonable
Edited by robboxr6t
  • Moar Powar Babeh
  • Member For: 19y 8m 16d
  Eugene said:
Re: After market boost controler.
I have played with these to, a manual GFB one does a good job, but gives you the same boost all the way through the range, set it and thats what you get everywhere.
the factory one does agood job, if its set up right, my car does go better with the aftermarket boost controler in, but it comes on too early and stays too long for my liking.
I think you can get electric / adjustable from the cab ones, but the factory system is fine, it needs to set up right, thats all.
Wog knows how to stop the boost solinoid clicking/fluctuating, i watched him do it.
<{POST_SNAPBACK}>
I have a Turbosmart Eboost 2 fitted to my car and i find its great. i had all sorts of issues from the clicking solenoid to boost spikes upwards of 18 to 20 psi. The tuner i WAS using had no idea bout how to control these issues so i fitted the Eboost to give me some control. Simon from Xtreme has tuned the car since and was able to solve all these issues. I still run the Eboost because i love the fact that when i start the car i can run around on 5psi of boost if its wet or my girlfriend or sister and "mates" are driving the car its down to probably around 200ish rwkw and if i want to go out and play race cars all i have to do is press a button on the dash board and i have 15psi and 300rwkw. There very pricey ( i paid around $740) but i the time (before i knew Simon or about this site) i was a cheaper option than blowing the a##hole out of my car... :spit:
but i would imagine any good tuner such as Simon from Xtreme should be able to sort those issues out... :spoton:
