robboxr6t Member 59 Member For: 19y 6m 13d Location: The sutho Shire Posted 16/01/06 09:46 AM Author Share Posted 16/01/06 09:46 AM they told me they replaced the actuator, they didnt say anything about the solenoid. I went to them because I was under the impression they were the best at it and they know the xr6t back to front. obvoiusly something is wrong if I have all of these mods and this problem? Link to comment https://www.fordxr6turbo.com/forum/topic/22684-funky-boost-curve/page/2/#findComment-335995 Share on other sites More sharing options...
rob82 Member 65 Member For: 19y 6m 17d Posted 16/01/06 09:54 AM Share Posted 16/01/06 09:54 AM I would say they have replaced the solenoid and not the actuator....The wastegate is held shut by a spring, when the correct boost is achieved the solenoid opens allowing a vacuum to pull the actuator open which then pulls the wastegate open, The vacuum is drawn from the intake side of the compressor.If the spring on the wastegate is cactus it will not remain closed even if the solenoid is shut..<{POST_SNAPBACK}>Close. Your right in saying that the wastegate is held shut by a spring however a vacumm reference is applyed to the top of the actuator in order to over come the cracking pressure of the wastegate spring. So in order for an 8Psi actuator to open and vent exhaust gas there must be at least 8psi of boost pressure on the top side of the acuator. Now when you want to increase boost over the acuator pressure you must bleed the vacumm/boost signal to the top of the actuator. For example if you bleed 4psi from the vacumm/boost signal you now have 8+4=12psi of boost pressure. Remember this only applies to internally gated turbo's. The boost control solenoid is able to bleed a certain amount depending upon its duty cycle and operating frequency and this is how the factory ECU controls boost.This all said, I havn't come across one BA actuator that has failed. Link to comment https://www.fordxr6turbo.com/forum/topic/22684-funky-boost-curve/page/2/#findComment-335997 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 1m 10d Gender: Male Location: Victoria Posted 16/01/06 09:56 AM Share Posted 16/01/06 09:56 AM The clicking solenoid issue should be long gone on an edited car. A new version of the software was released that fixed this problem, regardless it didn't produce a boost curve like that.I'd say your problem is tuner related, stock actuator can hold more boost than that. Link to comment https://www.fordxr6turbo.com/forum/topic/22684-funky-boost-curve/page/2/#findComment-335999 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 1m 10d Gender: Male Location: Victoria Posted 16/01/06 09:58 AM Share Posted 16/01/06 09:58 AM Elaborating I would say that's its going in and out of closed loop boost control, they probably have set the open/closed loop bounds large enough or not tuned the desired table correctly.Who are you? You must have something to do with the industry. Link to comment https://www.fordxr6turbo.com/forum/topic/22684-funky-boost-curve/page/2/#findComment-336000 Share on other sites More sharing options...
robboxr6t Member 59 Member For: 19y 6m 13d Location: The sutho Shire Posted 16/01/06 10:01 AM Author Share Posted 16/01/06 10:01 AM what should I be expecting to run with my mods in regards to boost and power.thanks heaps for everyones help Link to comment https://www.fordxr6turbo.com/forum/topic/22684-funky-boost-curve/page/2/#findComment-336002 Share on other sites More sharing options...
rob82 Member 65 Member For: 19y 6m 17d Posted 16/01/06 10:18 AM Share Posted 16/01/06 10:18 AM what should I be expecting to run with my mods in regards to boost and power.thanks heaps for everyones help<{POST_SNAPBACK}>It should run around 280rwkw consistent with your mods at around 12pound if tuned properly. Link to comment https://www.fordxr6turbo.com/forum/topic/22684-funky-boost-curve/page/2/#findComment-336009 Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 20y 5m 1d Location: Perth Posted 16/01/06 10:23 AM Share Posted 16/01/06 10:23 AM Elaborating I would say that's its going in and out of closed loop boost control, they probably have set the open/closed loop bounds large enough or not tuned the desired table correctly.<{POST_SNAPBACK}>I'd say you are on the money there. Link to comment https://www.fordxr6turbo.com/forum/topic/22684-funky-boost-curve/page/2/#findComment-336010 Share on other sites More sharing options...
rob82 Member 65 Member For: 19y 6m 17d Posted 16/01/06 10:32 AM Share Posted 16/01/06 10:32 AM Elaborating I would say that's its going in and out of closed loop boost control, they probably have set the open/closed loop bounds large enough or not tuned the desired table correctly.Who are you? You must have something to do with the industry.<{POST_SNAPBACK}>I work as an engineering programmer at Chiptorque on the Gold Coast. Link to comment https://www.fordxr6turbo.com/forum/topic/22684-funky-boost-curve/page/2/#findComment-336018 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 1m 10d Gender: Male Location: Victoria Posted 16/01/06 10:40 AM Share Posted 16/01/06 10:40 AM Good stuff Rob!I look forward to reading all the helpful info you have to offer us. Link to comment https://www.fordxr6turbo.com/forum/topic/22684-funky-boost-curve/page/2/#findComment-336029 Share on other sites More sharing options...
Blonk Iconoclast Donating Members 4,330 Member For: 20y 8m 9d Gender: Male Location: CH Posted 16/01/06 10:44 AM Share Posted 16/01/06 10:44 AM Elaborating I would say that's its going in and out of closed loop boost control, they probably have set the open/closed loop bounds large enough or not tuned the desired table correctly.Who are you? You must have something to do with the industry.I work as an engineering programmer at Chiptorque on the Gold Coast.Well Rob if you are an engineering programmer, then you would know the force that pulls on the diaphram / actuator open, is not called boost but vacuum and is not neccesarily 8 psi.Actually negative 8 psi would not even go close to opening the wastegate.Also the solenoid has no logic, it is open or closed, simple.I have heard of several faulty wastegates / actuators ...I had the problem on my T.....Replacing the actuator or wastegate is a major job not a 5 minute fix either.... Link to comment https://www.fordxr6turbo.com/forum/topic/22684-funky-boost-curve/page/2/#findComment-336035 Share on other sites More sharing options...
