robboxr6t Member 59 Member For: 19y 5m 1d Location: The sutho Shire Posted 16/01/06 08:12 AM Share Posted 16/01/06 08:12 AM (edited) hi guys, ive done a search, just wondering why my boost curve isnt consistent, and what could I do to remediate the situation?thanks.. Edited 16/01/06 08:13 AM by robboxr6t Link to comment https://www.fordxr6turbo.com/forum/topic/22684-funky-boost-curve/ Share on other sites More sharing options...
Blonk Iconoclast Donating Members 4,330 Member For: 20y 6m 28d Gender: Male Location: CH Posted 16/01/06 08:21 AM Share Posted 16/01/06 08:21 AM Your actuator sux............ Link to comment https://www.fordxr6turbo.com/forum/topic/22684-funky-boost-curve/#findComment-335943 Share on other sites More sharing options...
robboxr6t Member 59 Member For: 19y 5m 1d Location: The sutho Shire Posted 16/01/06 08:22 AM Author Share Posted 16/01/06 08:22 AM (edited) its a brand new garret one and my tuner tried another one today and same result. Edited 16/01/06 08:23 AM by robboxr6t Link to comment https://www.fordxr6turbo.com/forum/topic/22684-funky-boost-curve/#findComment-335946 Share on other sites More sharing options...
Blonk Iconoclast Donating Members 4,330 Member For: 20y 6m 28d Gender: Male Location: CH Posted 16/01/06 08:38 AM Share Posted 16/01/06 08:38 AM Why did you remove the stock one??And have you replace the solenoid?? Link to comment https://www.fordxr6turbo.com/forum/topic/22684-funky-boost-curve/#findComment-335954 Share on other sites More sharing options...
Robit28 Member 385 Member For: 19y 5m 24d Location: Brisbane Posted 16/01/06 09:00 AM Share Posted 16/01/06 09:00 AM I may be wrong, but would say that's normal. The T's boost is controlled by a solenoid that bleeds the air. Once the required boost is reached, the actuator arm opens to let exhaust out which in turn drops the boost. The computer sees the drop in boost, shuts the actuator and the boost rises again. Then the cycle begins again, this all hapens fairly fast and that's what your seeing on the dyno graph.Rob. Link to comment https://www.fordxr6turbo.com/forum/topic/22684-funky-boost-curve/#findComment-335962 Share on other sites More sharing options...
robboxr6t Member 59 Member For: 19y 5m 1d Location: The sutho Shire Posted 16/01/06 09:16 AM Author Share Posted 16/01/06 09:16 AM c and v told me it needed replacing cause it made this problem a while ago and also it made a clicking noise like a compresser when idling. now that I have had this replaced it still made the same problem so they told me to replace th cat so I did, and still the same bull sh$# Link to comment https://www.fordxr6turbo.com/forum/topic/22684-funky-boost-curve/#findComment-335970 Share on other sites More sharing options...
rob82 Member 65 Member For: 19y 5m 4d Posted 16/01/06 09:23 AM Share Posted 16/01/06 09:23 AM I would say 8psi acuator and a friday afternoon tune!!! Link to comment https://www.fordxr6turbo.com/forum/topic/22684-funky-boost-curve/#findComment-335974 Share on other sites More sharing options...
Blonk Iconoclast Donating Members 4,330 Member For: 20y 6m 28d Gender: Male Location: CH Posted 16/01/06 09:26 AM Share Posted 16/01/06 09:26 AM Not very clearDid they replace the actuator or the solenoid???? Link to comment https://www.fordxr6turbo.com/forum/topic/22684-funky-boost-curve/#findComment-335977 Share on other sites More sharing options...
rob82 Member 65 Member For: 19y 5m 4d Posted 16/01/06 09:26 AM Share Posted 16/01/06 09:26 AM Elaborating I would say that's its going in and out of closed loop boost control, they probably have set the open/closed loop bounds large enough or not tuned the desired table correctly. Link to comment https://www.fordxr6turbo.com/forum/topic/22684-funky-boost-curve/#findComment-335978 Share on other sites More sharing options...
Blonk Iconoclast Donating Members 4,330 Member For: 20y 6m 28d Gender: Male Location: CH Posted 16/01/06 09:35 AM Share Posted 16/01/06 09:35 AM I would say they have replaced the solenoid and not the actuator....The wastegate is held shut by a spring, when the correct boost is achieved the solenoid opens allowing a vacuum to pull the actuator open which then pulls the wastegate open, The vacuum is drawn from the intake side of the compressor.If the spring on the wastegate is cactus it will not remain closed even if the solenoid is shut.. Link to comment https://www.fordxr6turbo.com/forum/topic/22684-funky-boost-curve/#findComment-335985 Share on other sites More sharing options...
