  • Member For: 19y 10m 27d
Mine sits just below half way ,,turn on the A/C & its on half way. Turn off moter & goes 3 mm past half way...& today driving it was 34 deg & at about 4000 rpm it had no pull at all ,,but in the cooler evening no prob pulling hard right 2 the revlimeter WHY. :glad:
  • Replies 402
Posted Images
  • FPV521
  • Member For: 20y 8m 11d
  TurboDewd said:
normal operating temp for mine is about 11 o'clock, I.e. left of center.
it might crack the middle if if ive just turned off the car.
never seen it past halfway.
<{POST_SNAPBACK}>
Same Here :glad:
  • Woooooooosh
  • Member For: 19y 10m 9d
Same but if I switch it off and back on within a few minutes it will be on halfway for about 15 sec then goes back to about 11 o clock :laughing:
  GOLDIE said:
  LightningXR6T said:
I've spoken about this before and no one believes me. With the standard tune in my T runs at half way. With the CAPA generic 8psi (which according to 3 different boost gauges actually pulls 11psi) tune my gauge drops about 4mm ie: runs cooler!
<{POST_SNAPBACK}>
Not sure with the capa trunes but with the edit we have in the cooling fans are set to come on earlier than standard this may be why your gauge reads lower.
Ian
<{POST_SNAPBACK}>
Hey, not just a pretty face Ian :laughing::crybaby::kissmy:
vik...that's exactly the story,works a treat as well,what a bloke that tuna is :laughing:
  • Member For: 19y 11m 10d
Have a 160 Degree thermostat and a big Hyperflow cooler, It never gets to half and runs at 1/4 90% of the time!
  • XR68UZ
  • Member For: 19y 4m 7d
hey guys. went for a little drive last night with a few friends of mine. found a few rx7s and type r's and thought what the heck. I won ^^ however after my little adventure. I found that when I release the brake pedal, I can hear this crunching noise, which seems to be coming from the rear wheels. any ideas of whats wrong? im going to take it to the service guys once I recover from my wisdom teeth surgery but I wanted to have an idea of whats happening.
thanks
  • XR68UZ
another fault I have found. when I rev the engine in neutral, the tacho shoots up to 3krpm, bt then it just stops and then it sounds like its struggling to get over the 3k mark. is this normal?
its an ex telstra car so I was thinking it might be because of the stock ecu data (perhaps its like a safety measure?) not sure though.
