jordak Member 1,226 Member For: 20y 8m 10d Posted 19/01/06 06:19 AM Share Posted 19/01/06 06:19 AM if I gutter the cat and run a pipe straight throughdoes it hurt the motor of someway if amything ?<{POST_SNAPBACK}>If you want to "free flow" the cat why may want to consider getting an exhaust place to remove your cat (in tact)and replace it with with a section of pipe. Shouldn't cost any more than $50 and that way the whole thing is reversable. Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 9m 25d Gender: Male Location: Victoria Posted 19/01/06 06:34 AM Share Posted 19/01/06 06:34 AM So what was done to fix it? Can you alter the sensitivity of the knock sensors?The sensitivity can't be altered. The amount of timing that will be removed in any one event can be and it can be a different value at any point in the rev range.There less aggressive is a good way of describing it I guess. Link to comment Share on other sites More sharing options...
