New 'premium' Discs
aiboart
  • Colossal Member
  • Member For: 20y 6m 14d
:nono::pinch::fool::crybaby:
Ok here is what I have so far:
Option 1
Replace Rotors with DBA4000 series slotted discs and pads to suit, about $130 a corner plus pads, fitted myself.
Option 2
Upgrade standard brakes to OEM ford Premium Brakes, which I am assuming is bigger calipers, oval slotted rotors plus pads... are the lines included (ie braided)?... About $2000 depending on source, I can fit them myself.
Option 3
Add braided lines to option 1??? Is that what you are saying dingah? Sorry I'm a little confused with all the options and dont know the part numbers etc... If I kept my standard calipers and added braided lines to it how does this make it better?
If someone could give the pros and cons to all these options, I would be very grateful. Thanks! :blush:
  • Replies 60
  • Member For: 19y 8m 15d
im no help with your q steve, but put my name down for a pair of front slotted dba rotors if that's what you decide to go for..
the brakes didn't go too well on that cruise hey.
dingah,
im also interested in info on the braided lines for the dba setup..
~cost??
EDIT: and to throw another spanner in the mix, is it worth changing the brake fluid at all??
are their better options than what we get from the factory?
Edited by XR06T
  • Member For: 20y 2m 6d
Yeah from what I hear, if you change brake fluid go for the best you can afford.
<{POST_SNAPBACK}>
The more frequent you replace your brake fluid, the better.
A word of caution though, competition fluids are for competition use only and will not last long in street application due to the fluids' tendancy to absorb moisture. I'd steer away from racing-type fluids and go for a good DOT 3 or DOT 4 fluid and replace it at least once a year, preferably every six months.
  • Expert
  • Member For: 20y 11d
Hello everyone, been watching this thread and its very interesting.
Its good to see that we all have our own opinion, but at the same time help each other with questions asked. :crybaby:
I have been looking at upgrading my brakes for sometime now. I haven't been happy with Fords STD brakes since I first brought a
BA XR8 ute, and its carried onto my new car. (shutter ect ect)
Today I went on a hunt. Local Repco quoted me $2400 for complete upgrade set of PBR including lines.
Went to local Tyre mob who I have been dealing with for about 8 years, quoted me DBA Kangaroo Paw Slotted Rotors front and back + Bendix Ultimate Pads - $880 fitted. They said no need to change the calipers as I all ready have PBR on.
What is your though on the Package from the tyre mob. I'll still change the lines in the furture.
Aaron
Guest newl
  • Guests
<{POST_SNAPBACK}>
If the shudder you're referring to is the steering wheel bobbing back and forth, haul it back to the dealer and tell them to fix it as that'd be uneven rotor wear which is a warranty issue which normally would mean them replacing the rotors. May as well get what you can from them before you replace 'em. :)
  • Expert
Thanks newl, I'll just might try that. I thought that brakes were not covered under warranty.
The car is still under new car warranty and has almost 36,000. The other day I checked the brakes and found on the drivers side front rotor a grove spaning the disc right in the middle about 1mm wide and I don't know what from, think it maybe caused by uneven wear from the pads. YES or NO?
Either way I'll hit Ford up.
  • Crusty aviator
  • Member For: 20y 8m 19d
Ford premos do not include braided lines but the PBR premo upgrade kit does. It helps firm up the feel but is not a 'vital' addition. No info on cost/availbility of lines, sorry.
Always run the best fluid you can afford and flush every 12 months or so.
Standard and Premos are all made by PBR, the Premos and PBR upgrade both keep exactly the same rear callipers, only difference are the rotors - no size difference but slotted.
Aaron's all round DBA and Ultimate set-up sounds good value if they were DBA 4000 slotted, suspect they might not be though.
  • Member For: 20y 1m 9d
Yeah the rotors are covered... someone was telling me they had a lifetime warranty... so if they are skimmed completely you get a new set.
The brake system is only covered for 50,000km. After that there is no warranty, that's right NO 3 years on brakes.
A friend was knocked back by the dealer at 75000km, rang Ford Customer Service, was told the same, and after 30mins they agreed to cover the cost of the machining done.
Also for braided lines I found this in the Ford Mods Forum. Don't know if they have them for the BA.
Hey Guys And Gals,
FernTree Gully Auto Salvage now have Braided brake lines available for EA-ED and EF-EL
They are available in: Red
Blue
Black
Grey
Full sets for front and rear are available at $280 a set Inc Freight anywhere in Australia for Fordmods Members
Call us or email us today
(03) 9758 6900 or ftgautosalvage@optusnet.com.au
