ms700 Moderating Team 10,170 Member For: 21y 11m 5d Gender: Male Location: Sydney Posted 11/03/06 01:16 AM Share Posted 11/03/06 01:16 AM Guys,I am tring to fit a towbar, but what the do you use to get those plastic plugs off. They have a cross in the top which implies a phillips head, but they dont work. They are in the rear guards and in the middle bottom of the bumper.How do you get them off without braking them???<{POST_SNAPBACK}>They are pricks to get out, I usually use a jewellers screwdriver to pull the centre (where the phillips is) out, once this is out pull the whole thing out.<{POST_SNAPBACK}>Cheers, I'll give that a go. I have been trying to move the whole plug - I didnt realise just the centre bit comes out.<{POST_SNAPBACK}>Correct, they are absolute pains to remove.Get a small flat blade screwdriver, and try to wedge it between the outer edge and the phillips inside bit, and then use a phillips to remove it. Once you remove the first clip, you will know what im talking about. Link to comment Share on other sites More sharing options...
Flukey Seriously Flukey Member Donating Members 4,354 Member For: 20y 9m 15d Gender: Male Location: Melbourne Posted 11/03/06 01:40 AM Share Posted 11/03/06 01:40 AM Guys,I am tring to fit a towbar, but what the do you use to get those plastic plugs off. They have a cross in the top which implies a phillips head, but they dont work. They are in the rear guards and in the middle bottom of the bumper.How do you get them off without braking them???They are pricks to get out, I usually use a jewellers screwdriver to pull the centre (where the phillips is) out, once this is out pull the whole thing out.Cheers, I'll give that a go. I have been trying to move the whole plug - I didnt realise just the centre bit comes out.Correct, they are absolute pains to remove.Get a small flat blade screwdriver, and try to wedge it between the outer edge and the phillips inside bit, and then use a phillips to remove it. Once you remove the first clip, you will know what im talking about.Farking car is too low, also makes it a b**ch to work on. Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 8m 11d Gender: Male Location: Victoria Posted 11/03/06 02:03 AM Share Posted 11/03/06 02:03 AM The good old scrivets.Use them once and then there farked! Link to comment Share on other sites More sharing options...
citric acid xr6t Donating Members 449 Member For: 21y 8m 6d Gender: Male Location: Brisbane Posted 11/03/06 02:56 AM Author Share Posted 11/03/06 02:56 AM Yeah I stuffed all of mine when I pulled them out. But you can buy replacements from Supercheap for just a couple of bucks. Link to comment Share on other sites More sharing options...
