  • TEAM BA
  • Member For: 20y 4m 10d
okay just a heads up for those of you with diff clunk, 3000km (about 2 months) I had pretty much my entire rear end replaced after breaking a control arm, last week I started getting the infamouse diff clunk in reverse, at about 3000rpm in second when slowing down and also on the occasional gear shift, it sounded like it was comming from the center rear but slightly to the passenger side. All pretty common all pretty normal anyway I took the car in for a service on tuesday and asked for them to check it out.
I picked the car up yesterday and was told that they had re-torqued the suspension and the clunk was gone! sure enogh it is, so it had nothing to do (in this case) with the diff but was almost the exact same sound as the clunking diff makes.
For those with the clunk, maybe its not your diff.
p.s: I have had diff clunk that resulted in 2 broken drive shafts so I do know what it sounds like :)
https://www.fordxr6turbo.com/forum/topic/22105-diff-clunk-not-the-diff/
  • Member For: 21y 9m 29d
<{POST_SNAPBACK}>
I have a ute and it clunks and I have not control arms just a big simple axel clamped to leaf springs. Its the diff! :spoton:
  • TEAM BA
  YOOT said:
I have a ute and it clunks and I have not control arms just a big simple axel clamped to leaf springs. Its the diff!  :stirthepot:
Im not trying to say that its the control arm, more that it may not be the diff it may be the control arms, obviously with no control arms in the ute it is your diff :)
I had never heard of the clunking being related to the suspension that's all :)
  • Member For: 19y 4m 22d
<{POST_SNAPBACK}>
Ford misdiagnosed a broken engine mount as suspension noise. The sympton was clunking from the front end. They simply tightened everything and sent me on my way - with the same clunk. Warranty fix now done with new mount and no clunk.
Also previously had a clunk that WAS fixed by tightening suspension.
  • Member For: 19y 7m 27d
Rear end clunk or dull knocking noise, I've had my rear end (suspension that is) tightened up on a few occasions until this last time when I had the rear sway bar link pins replaced. Good as gold now - er well, I hope it lasts.
  • Member For: 19y 11m 4d
I did a post a while ago about a clunking diff at:
http://www.fordxr6turbo.com/forum/index.ph...id=291344&st=0&
The local dealer checked it out and said the diff needed a rubber damper replaced. I waited a couple of weeks for it and booked it in for the 30K service and to have the damper fitted. End of the day I arrive to pick up the car and was told the standard Ford procedure is put a diff additive in first to see if that will cure the problem, which they did. If that doesn't work, THEN they replace the damper. If that doesn't fix it, then they can think about replacing the diff.
And by the way, they forgot to do the 30K service so bring it back another day :nono:
Took the car back Sat morning (they actually did the service this time though what they did is another story in itself!) and then was told it's not the diff but cracked bushings in the rear suspension that's causing the clunking. Bring it back in a couple of weeks.........again...................... :nono:
You guys in the larger cities are lucky you have more than 1 Ford dealer
  • 1 month later...
The dealer replaced the suspension bushings and it appears the clunk has disappeared. It's only been a couple of days so far so I hope this is the permanent fix. I'll post again if the clunk comes back. Gee, did they get it right this time
