iTec TEAM BA Donating Members 1,755 Member For: 20y 24d Gender: Male Location: North of The Bridge Posted 22/12/05 04:31 AM Share Posted 22/12/05 04:31 AM okay just a heads up for those of you with diff clunk, 3000km (about 2 months) I had pretty much my entire rear end replaced after breaking a control arm, last week I started getting the infamouse diff clunk in reverse, at about 3000rpm in second when slowing down and also on the occasional gear shift, it sounded like it was comming from the center rear but slightly to the passenger side. All pretty common all pretty normal anyway I took the car in for a service on tuesday and asked for them to check it out. I picked the car up yesterday and was told that they had re-torqued the suspension and the clunk was gone! sure enogh it is, so it had nothing to do (in this case) with the diff but was almost the exact same sound as the clunking diff makes.For those with the clunk, maybe its not your diff.p.s: I have had diff clunk that resulted in 2 broken drive shafts so I do know what it sounds like Link to comment Share on other sites More sharing options...
YOOT Member 1,201 Member For: 21y 6m 12d Location: Birkdale Posted 22/12/05 09:38 PM Share Posted 22/12/05 09:38 PM okay just a heads up for those of you with diff clunk, 3000km (about 2 months) I had pretty much my entire rear end replaced after breaking a control arm, last week I started getting the infamouse diff clunk in reverse, at about 3000rpm in second when slowing down and also on the occasional gear shift, it sounded like it was comming from the center rear but slightly to the passenger side. All pretty common all pretty normal anyway I took the car in for a service on tuesday and asked for them to check it out. I picked the car up yesterday and was told that they had re-torqued the suspension and the clunk was gone! sure enogh it is, so it had nothing to do (in this case) with the diff but was almost the exact same sound as the clunking diff makes.For those with the clunk, maybe its not your diff.p.s: I have had diff clunk that resulted in 2 broken drive shafts so I do know what it sounds like <{POST_SNAPBACK}>I have a ute and it clunks and I have not control arms just a big simple axel clamped to leaf springs. Its the diff! Link to comment Share on other sites More sharing options...
iTec TEAM BA Donating Members 1,755 Member For: 20y 24d Gender: Male Location: North of The Bridge Posted 23/12/05 01:45 AM Author Share Posted 23/12/05 01:45 AM I have a ute and it clunks and I have not control arms just a big simple axel clamped to leaf springs. Its the diff! Im not trying to say that its the control arm, more that it may not be the diff it may be the control arms, obviously with no control arms in the ute it is your diff I had never heard of the clunking being related to the suspension that's all Link to comment Share on other sites More sharing options...
Schmooth Member 105 Member For: 19y 1m 5d Location: Canberra Posted 23/12/05 02:09 AM Share Posted 23/12/05 02:09 AM I had never heard of the clunking being related to the suspension that's all <{POST_SNAPBACK}>Ford misdiagnosed a broken engine mount as suspension noise. The sympton was clunking from the front end. They simply tightened everything and sent me on my way - with the same clunk. Warranty fix now done with new mount and no clunk.Also previously had a clunk that WAS fixed by tightening suspension. Link to comment Share on other sites More sharing options...
galconn Member 101 Member For: 19y 4m 9d Posted 23/12/05 03:04 AM Share Posted 23/12/05 03:04 AM Rear end clunk or dull knocking noise, I've had my rear end (suspension that is) tightened up on a few occasions until this last time when I had the rear sway bar link pins replaced. Good as gold now - er well, I hope it lasts. Link to comment Share on other sites More sharing options...
hafadude Donating Members 245 Member For: 19y 7m 18d Gender: Male Location: Cairns Qld Posted 27/12/05 12:05 AM Share Posted 27/12/05 12:05 AM I did a post a while ago about a clunking diff at:http://www.fordxr6turbo.com/forum/index.ph...id=291344&st=0&The local dealer checked it out and said the diff needed a rubber damper replaced. I waited a couple of weeks for it and booked it in for the 30K service and to have the damper fitted. End of the day I arrive to pick up the car and was told the standard Ford procedure is put a diff additive in first to see if that will cure the problem, which they did. If that doesn't work, THEN they replace the damper. If that doesn't fix it, then they can think about replacing the diff. And by the way, they forgot to do the 30K service so bring it back another day Took the car back Sat morning (they actually did the service this time though what they did is another story in itself!) and then was told it's not the diff but cracked bushings in the rear suspension that's causing the clunking. Bring it back in a couple of weeks.........again...................... You guys in the larger cities are lucky you have more than 1 Ford dealer Link to comment Share on other sites More sharing options...
curious Member 504 Member For: 21y 1m 29d Location: sun, beach and plenty of T T's Posted 27/12/05 03:37 AM Share Posted 27/12/05 03:37 AM two new drive shafts, clunk gone..... now just got to get it from popping out of second.. ahhhhhhhhh Link to comment Share on other sites More sharing options...
hafadude Donating Members 245 Member For: 19y 7m 18d Gender: Male Location: Cairns Qld Posted 01/02/06 02:45 PM Share Posted 01/02/06 02:45 PM The dealer replaced the suspension bushings and it appears the clunk has disappeared. It's only been a couple of days so far so I hope this is the permanent fix. I'll post again if the clunk comes back. Gee, did they get it right this time 1 Link to comment Share on other sites More sharing options...
