  • Member For: 19y 9m 28d
I've searched but can't find anything except for this thread http://www.fordxr6turbo.com/forum/index.ph...5&hl=thermostat , which realy didn't answer the question.
I read somewhere that the eng temp is monitored by the PCM and makes adjustments to fuel, timing etc! The hotter the engine gets, the less power is allowed by the PCM.
I have also been lead to believe that the Typhoon has a different deg thermostat!
A freind has a MKI and I have a MKII both auto's. His runs around 1/4 on temp gauge, where mine runs a mic hair under half. (On the same road, at the same time, same ambient temp ect)
Can anyone shead some light on this?
https://www.fordxr6turbo.com/forum/topic/21990-engine-temp-vs-performance/
  • Moar Powar Babeh
  • Member For: 19y 7m 6d
i had a cooler thermostat fitted by Simon from Xtreme ford tuning. he also lowered the cut in temp of the fans to compensate for the cooler thermostat using my flash tuner. I feel it makes a big difference to power. the car pulls harder running cooler and stays cooler when your really giving it a hard time
  • Team Bute
  • Member For: 21y 9m 14d
Mine sits at about the 10 0'clock mark on factory gauge under normal driving.
I have an engine oil temp gauge fitted, and it sits on 80 deg C. Thermostat was changed to run cooler. After a few short sprints, both water and oil temps rise..
water temp just below half, and oil temp up to about 90 deg C.
Fan is operating at full speed, and temps come back to 80 degC quite quickly.
As to ECU monitoring engine temp for performance ??? Don't know.
Certainly the charge air temp drawn into manifold IS monitored and definitely affects performance. By same token, higher under bonnet temps will heat up the entire intake system, including radiated heat from radiator heating intercooler core, resulting in higher air intake temps and therefore drop in performance.
The cooler the engine bay is, therefore the better the performance.
A mod to incorporate to the "T" is reducing temps under the bonnet. Especially needed if circuit racing. As you increase power, there is a BIG increase in temps under the bonnet.
I've heard of a simple technique... to remove the rubber seal across the front and rear edges of the bonnet. This will allow air to flow over the top of the engine ridding the area of heat .
Not sure how effective this is, and the effect on aerodynamics.
HAS anyone done this?
Of course a much better option is to incorporate some stylish, effective and aerodynamic vents.... A few guys have modified bonnets... Any feedback?
Or maybe some side vents on the trailing side of the front guards might look OK?
Where's the photo-shop stylists..... where's the Ausie equivalent of Chip Foose?
tom
  • Member For: 19y 5m 10d
Yes the PCM will remove performance when the engine is running hotter. It does this by removing boost and timing and increasing AFR's. If you've seen the factory desired boost table you would see as the MCT(mass charge temp) gets to a certain level the desired boost is almost halved hence reducing power.
As for removing the bonnet seals it will have absolutely no efect on areodynamics whats so ever, after all it's only a falcon but yes it will remove under bonnet heat.
These motors are extremely heat dependant and while you can get away without upgrading the IC for a stage 1 upgrade stage two would allmost be a definate in my books. In one dyno ramp you can see the CHT increase by up to 10 deg Celcius.
