  • Moar Powar Babeh
  • Member For: 19y 7m 2d
I expect my car will be in bits that weekend but it might not be a bad shake down run for @turboknapp and the blue meanie
  • Will do skids for food
  • Member For: 13y 5m 21d
If I remove my drivers seat. Will I get any error codes when I plug it back in?
Something is messed up under there.
It's like it doesnt lock properly into position and slides forward an inch or two under brakes.
Kinda off putting.
Cool. its been doing it for months but I havent had the time or the inclination to pull it out and look at it.
I still havent even washed the ute since the down south cruise !!
So I might do that too....maybe.
Edited by Boganspeed
  • Moar Powar Babeh
Key off/out and disconnect the battery and give it half an hour before disconnecting the air bag (if fitted) and pre tensioner connectors
I bumped into a mate of yours on my last trip up to Karratha Phil, bloke called Murray?
Yeah that's Morry. He mentioned that on the weekend. Top bloke and always ready for a chat.
  • Moar Powar Babeh
Yeah I felt sorry for the bloke sitting between us. He asked if we wanted to swap seats and Morry and I both replied "NO!" Feeling where hurt I think.
  • Member For: 8y 6m 4d
Hey guys
Couple of questions:
1. Water temp, seems to always be sitting around 1/4 on the temp gauge (to the left). Should I just swap out for a new thermostat, or should I try burping the system? If burping, how is it done on the FG XR6T? If changing thermostat, what is the procedure? Just undo the top hose and thermostat housing, change over and top up coolant? Can I also assume this is related to my sh*tty fuel economy?
2. Outside air temp seems to be always way cooler than what it is? It seems like the temp sensor in the passenger side mirror needs to be replaced. On my 08 FG mkI can I just change the temp sensor, or does the whole mirror housing have to be changed?
Thanks
Martin
