  • Member For: 11y 11m 25d
Thought BOV stays in same place and you run longer supplied hose from intake elbow to BOV?
Just rip the whole thing out and block holes with chair stoppers.....not needed apparently and get better flutter noise lol
Roger that. Obviously could just ask manufacturer, but doubt it will be cheap. I have NFI, but looks like standard hose from any auto shop (but I'll shut up and let someone smart confirm).
Think I have a Plaz one somewhere at home....I could maybe measure and give you dimensions? I'd sell you mine, but I'll probably need it later if I resell my kit in the future
  • Sandtrap Motorsport
  • Member For: 16y 5m 26d
righto, making a simple task painful to read.
go to Couplers during your travels, purchase the non-high-pressure rated hose (less layers, easier to put on) ... it's like sub $8.95 a metre if I recall
  • Like 2
  • Get It To Wheelspin Uncontrolably Then Give It Another 5 Pounds
  • Cruise Control
  • Member For: 14y 6m 29d
I have no BOV and only get flutter if I put my foot into it. Normal driving you would think mine is a n/a..... Infact, compared to everyone else on here mine seems like a n/a
You fitted that cooler yet Steve? Or to busy putting the house back together
  • Member For: 12y 2m 24d
Too busy resting his balls on all your houses surfaces apparently?
Do the cooler together it'd be a *beep* to do alone, gotta hold up that big radiator support bar while you drill it etc
  • Moar Powar Babeh
  • Member For: 19y 7m 27d
  On 21/10/2015 at 3:18 AM, huggy_b said:
Can anyone suggest what to use for BOV recirc line after changing to turbo side intake? The 25mm ID line that goes back to the intake pipe from BOV. Obviously it needs to be a fair bit longer than the stock rubber thing. Any help on where to get would also be great.
I've got a heap of surplus 25mm I'd silicone hose (blue hence surplus) or some 25mm id black rubber hose if that'll help?
Can throw it in the boot if your passing the airport in your travels tomorrow or Friday.
  • Member For: 12y 29d
Done, black rubber is good.....old man spec LOL.
I'll PM you later.
Cheers.
  • Moar Powar Babeh
If you take the black.....you gotta take the blue as well.....
  • Like 2
  • Member For: 17y 5m 26d
I am thinking about finally blocking my BOV off after 7 years, after driving your stock F6 ute on that furniture run. Flutters easy as on stock boost! Mine's not stock, so could be a bit much though compared to yours though, which is stock.
Stock.
  • Like 2
