  • Dropping a turd
  • Member For: 17y 7m 11d
  On 30/07/2015 at 11:52 PM, Ralph Wiggum said:
Do your jacks extend out to pick up on the body lifting points?
Yep. They are hydraulic with air
  • Member For: 12y 13d
My clunk noise isnt when braking...its like something is loose. Its hard to explain but its like the springs rattle on the shock or something and only for a second when going over little bumps in the road. I'm hoping the rear clunk is the wholesale suspension pins washer needs to be machined (like what Stipes said a while back).
  • New Member
  • Member For: 10y 1m 19d
  On 30/07/2015 at 4:43 AM, arronm said:
I have a set of alloy mags Late model camira pattern you can have for a bottle of wild turkey. Will post a pic tonight. 235 40 18. Had them on My trailer before I changed to ford pattern
I'll calculate to see if it will work currently they are 185/60/14
Sent from my SM-N910G using Tapatalk
  • Dropping a turd
  On 30/07/2015 at 11:42 PM, Ralph Wiggum said:
Nice one Double R Ron. Your back will thank you.
My workshop is under the house main roof. Ceiling is 30 courses. Gives enought lift on the hoist for service work,brake/suspension work/trans service etc. Just not ideal for slinging gearboxes etc.
In summary doitfgt.
My ceiling is only 25 courses
  On 31/07/2015 at 10:05 AM, Zaff88 said:
Peter have you checked your power steering? Turn your steering wheel full left or right and see if you get clunk noise then.
Thanks for the suggestion Zaff...I don't get the clunk when im turning...in stationary position it just makes a little pump noise (which I assume is normal)..and when driving I can hear it when I'm going straight. It really only happens if the road is a little dodgy.
Got my car in 2moro morning for a balance on all 4 wheels....should hopefully sort most of the vibrations (cause it did last time and still rekon a weight must have fallen off somehow)...we shall see I suppose
Oh and thanks for the new member name Ralph :spoton:
  • Member For: 17y 6m 14d
