  • Sandtrap Motorsport
  • Member For: 16y 6m
Anybody wanting to swap a 3540 for a 3576 ?
You keep your rear housing.
Was told it was in good condition when removed for a precision 6466
Edited by Tocchi
  • To Loud
  • Member For: 13y 5m 25d
Nope, wasn't me. I was in guildford at 07:23am on my way to work.
decisions, decisions, decisions.
  On 23/04/2015 at 8:01 AM, TaHa said:
Pipe work - Sounds good
Ok I've sorted my pipe work, picked up FG stuff today.
If you want, I'll do all of this stock piping for what I paid :) $100
  • Member For: 17y 6m 1d
  On 24/04/2015 at 3:33 AM, Krazy Kyle said:
thought it was him.... Guy can drive.
Over on AL they love to call R35s soulless computers that don't need a driver. They often sound like arse too. Still wouldn't say no to one, would love to flog the tits off it around the burbs between jobs daily hahaha
  • Member For: 12y 2m 29d
You still have to steer and brake the thing.. just has awesome traction control and auto gearbox
You should feel the launch control in em...intense
  • Will do skids for food
  • Member For: 13y 6m 21d
  On 23/04/2015 at 3:56 PM, Z2TT said:
There is no need for a aftermarket flex plate the fault does not lie in the flex plate it lies in the way it is attached.
Ive wondered if, before it failed, you were to replace the bolts with arp bolts and loctited them, or even the oem bolts, if that would prevent it from happening.
If you could do that without dropping the trans, it would be worth it.
If you have to pull the box, then you may as well add $250 for a nizzy one.
I dont even know if theres an inspection cover. Never bothered to look.
  • Moar Powar Babeh
  • Member For: 19y 8m 2d
Box would still need to come out. Bolts loosening off is a symptom not the cause. The issues is the thickness and hardness of the stock plate. The torque from the engine distorts the metal on the loaded side of the plate and once the plates hole are no longer a tight fit on the bolts its starts to move under load and its all over.
Early bfs had issues with not loctite on the bolts and it would effect even stock cars bf2 on,the plate is the issue.
