  • Member For: 12y 2d
Wow....replies to me in the public area :spoton:
Maybe this should be a mod before tune as well.....like the surge tank, for being 'cheap insurance'
When the plate goes does it do any damage to other parts?
Mod list never seems to end lol
  • All stock bar the k&n panel filter
  • Member For: 13y 2m 14d
  On 23/04/2015 at 12:44 AM, GeGe6 said:
As you might have read already I done my Flex plate last night at Motorplex.
Anybody know where I can get it fixed around O'conner and surrounding areas?
Or are my only options to put it on a flat bed and send it to MT/XFT?
That sucks man! Sorry to hear!
  • Member For: 17y 6m 3d
Ralph warned me that flex plate being stuffed can cause major damage to the crankshaft I think? If driven on that is. IE engine damage.
I drove mine (carefully) back to home in the hills and to XFT the next morning but I advised Mick he should get it tilt trayed and avoid possible major damage :)
Mine came loose after a skid on the line...still drove it down the strip (dumb). It doesn't rattle around if it's kept under load but as Ralph said, don't try. Could have ended in tears for me.
Edited by -Stever-
  • Like 2
  On 23/04/2015 at 2:15 AM, Ralph Wiggum said:
I'm running the beefed a up Nizpro plate. Perfectly adequate IMHO around $220 delivered with new ARP bolts from memory. Problem is common as big toes. As I mentioned before not a difficult job (3hrs labour max on a hoist) Nizpro are very specific about how the plate is installed so if the bloke doing the work follows the directions you won't have and issue.
Just got off the phone to them....Nizpro Flex Plate (I think he said 'heavy duty') is $285 with ARP bolts + Postage.
Ralph do they only have the one type of flex plate? Also did you weld the bolts on, like some people have been saying in other threads? Or just loctite and correct torque?
Looks like I'll be adding another thing to the list when tune happens.....approx. $600 installed (going by estimated timeframe above)....definitely get MT to do it and hopefully they know the correct torque and type of loctite to use.
  • Moar Powar Babeh
  • Member For: 19y 8m 5d
Price (or my memory of) may have changed. Either way worth the effort. I didn't weld the bolts. No need IMHO when using the double thickness plate with the arp bolts and the correct install procedure.
Nizpro includes detail instructions but essentially the procedure is to (one you have clean/tapped the threads in the crank) install the flex plate with the original bolts torque to a nominal torque (30nm from memory) and the remove then one at a time in and replace them with the ARP bolts (with loctite correctly applied) and then torque the arp to the same nominal torque. Once all the arp bolts are installed then torque them to the full spec (90nm i think) in a criss cross pattern.
The process ensures the plate is fully seated and no loctite winds up between the flex plate and crank and the plate is square with the crank.
  • To Loud
  • Member For: 13y 5m 27d
  On 23/04/2015 at 4:25 AM, kjoy064 said:
Is anyone after a BF GT3540 Turbo for a decent price? $600 done about 1000km's.
SMS sent.
  • Sandtrap Motorsport
  • Member For: 16y 6m 3d
Damn kjoy that's cheaappp :) good pickup for anybody !
Now, given I can't access classifieds, does anybody want some Barra parts (motors, motor parts, etc) for cheap?
Cleaning out my garage. Mostly BA stuff - blocks, brackets, intakes, heads, blah blah
Will have FG crank / Pistons / rods soon too
