masda74 To Loud Gold Donating Members 4,112 Member For: 13y 3m 8d Gender: Male Location: WA, Perth Posted 13/12/14 04:30 AM Share Posted 13/12/14 04:30 AM Did you use one of the spring compressor tools? Link to comment Share on other sites More sharing options...
RB Snake Donating Members 327 Member For: 11y 2m 16d Gender: Male Location: Perth SOR Posted 13/12/14 04:43 AM Share Posted 13/12/14 04:43 AM Nah, I don't have one. It'd be a bit difficult using one on the rear wouldn't it? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 15d Gender: Male Location: Perth Posted 13/12/14 06:04 AM Share Posted 13/12/14 06:04 AM Yo Dawg, we heard you like pictures of phones so we put a picture of a phone in your picture of phone 1 Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 3m 8d Gender: Male Location: WA, Perth Posted 14/12/14 12:17 AM Share Posted 14/12/14 12:17 AM Nah, I don't have one. It'd be a bit difficult using one on the rear wouldn't it?From what I have read up on the intermaweb, you can use the spring compressor tool on the front and the rear.I am not sure how much the tool costs and if anyone has one already. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 4m 11d Gender: Male Location: Perth Posted 14/12/14 12:22 AM Share Posted 14/12/14 12:22 AM Drop the bottom of the shock and the sway bar pull the suspension down and the rear spring will come out. Link to comment Share on other sites More sharing options...
RB Snake Donating Members 327 Member For: 11y 2m 16d Gender: Male Location: Perth SOR Posted 14/12/14 12:39 AM Share Posted 14/12/14 12:39 AM That's what I thought Arron, but I couldn't get them out. Doesn't matter anyway, I've bought some spring compressors, gonna need em for the fronts and on my brothers 4x4. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 15d Gender: Male Location: Perth Posted 14/12/14 01:03 AM Share Posted 14/12/14 01:03 AM The control blade bush limits the downward movement. If you loosen the two nuts that secure it the lca will drop. 1 Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 5m 16d Gender: Male Location: Perth, WA Posted 14/12/14 03:27 AM Share Posted 14/12/14 03:27 AM Get some stands and lift both sides of the rear and put the car on stands. With both wheels off and the bottom shock nut off it's pretty easy to remove the stock springs. Shorter springs should be even easier. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 3m 14d Gender: Male Location: Probably above atmospheric pressure Posted 14/12/14 05:00 AM Share Posted 14/12/14 05:00 AM I was foiled by the control blades when I was trying to install new spring pads. I was able to change out the rear springs to shorter one myself no issues as the control blade was so shot. After putting the new shorter springs in and later having new control blade bushes fitted, I was no longer able to remove the shorter King springs when I had a go. Pissed me off!But always remember "a tight bush is better than a loose one". 2 Link to comment Share on other sites More sharing options...
RB Snake Donating Members 327 Member For: 11y 2m 16d Gender: Male Location: Perth SOR Posted 14/12/14 05:28 AM Share Posted 14/12/14 05:28 AM (edited) Thanks guys, so how did you get around that problem Steve? Did you use the spring compressors, or remove the 2 bolts holding the control arm? I should probably fit new pads while their out as well. Edited 14/12/14 05:37 AM by RB Snake Link to comment Share on other sites More sharing options...
