GeGe6 Donating Members 1,978 Member For: 12y 5m 19d Gender: Male Location: Perth, SOR Posted 29/10/14 12:03 PM Share Posted 29/10/14 12:03 PM Ok have been in negotiations with the suppler of the catch cans.The original price of the cans are $95.00 + $14.00 delivery, total $109.00.I have managed to negotiate an $85.00 flat rate including delivery to one address.This is based on s minimum of 7-10 units.You can choose silver or black in color.I will be happy to pay for all cans using my PayPal account and receive delivery and disperse from there. I will send a PM to all in the above list. 1 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 1m 29d Gender: Male Location: Perth Posted 29/10/14 12:47 PM Share Posted 29/10/14 12:47 PM (edited) Mine our here. I dont have two the same. Remember feed from the bottom and out at the top. And the PCV valve circuit needs a one way valve. Preferably on the outlet so you dont pressurise the can. Edited 29/10/14 12:50 PM by arronm Link to comment Share on other sites More sharing options...
Krazy Kyle Get It To Wheelspin Uncontrolably Then Give It Another 5 Pounds Cruise Control 2,697 Member For: 14y 2m 5d Gender: Male Location: Work Posted 30/10/14 10:38 PM Share Posted 30/10/14 10:38 PM sooooo... inline turbo filtertrans oiloil catch canThe list is growing. would love to hit up Phil for a weekend but I'm not on dry land until December-ish, and even then between Christmas events and travelling to see family its looking a bit busy. I am hoping to make WAW on the 26th of November if anyone is keen. I have a 400RWHP statesman to beat before I start modding mine. after that he is looking at installing a 6.2 supercharged LSA motor, and I'm looking at the usual stuff to get mine to ~380rwkw. Then we will hit the drags again. Gotta have some motivation I guess. 1 Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 1m 2d Gender: Male Location: Probably above atmospheric pressure Posted 30/10/14 11:15 PM Share Posted 30/10/14 11:15 PM I'll head down with you and have a stab at the 1/4 again. Been thinking about it for a while now. Link to comment Share on other sites More sharing options...
Krazy Kyle Get It To Wheelspin Uncontrolably Then Give It Another 5 Pounds Cruise Control 2,697 Member For: 14y 2m 5d Gender: Male Location: Work Posted 30/10/14 11:51 PM Share Posted 30/10/14 11:51 PM on second thought, I don't want a half paint prep'd car beating me..... 1 Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 3d Gender: Male Location: Perth Posted 31/10/14 12:22 AM Share Posted 31/10/14 12:22 AM Mine our here. I dont have two the same. Remember feed from the bottom and out at the top. And the PCV valve circuit needs a one way valve. Preferably on the outlet so you dont pressurise the can.To reiterate Double R Ron's point, PCV side has a stock check valve. The valve is the same disc style valve as the NA engine so you can probably guess how well they work with 20psi up their behinds?I use a speed flow 610-06 Check valve (4 psi cracking but I remove the spring so it will open under vacum) and two speed flow 410-06 -6 male to -6 (3/8) hose barb.The reason for the check valve it two fold-1: Prevent pressurising the can under boost2: Prevent pressuring the crank case under boost.If you only plan to run 1 can I would recommend it goes on the PCV circuit WITH a check valve. If you don't run the check valve the crankcase pressure will continue to force oily crank case air into the breather circuit it and it will do the rounds through the turbo and into the cooler.tl:dr1 Can PCV circuit with the check valve = good2 Cans PCV circuit with the check valve and second can on Crankcase Breather = Best 1 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 1m 29d Gender: Male Location: Perth Posted 31/10/14 01:16 AM Share Posted 31/10/14 01:16 AM Or be like Grug and blow your dipstick out. Why hasn't anyone pointed out I have my one way valve not in the best location Link to comment Share on other sites More sharing options...
Krazy Kyle Get It To Wheelspin Uncontrolably Then Give It Another 5 Pounds Cruise Control 2,697 Member For: 14y 2m 5d Gender: Male Location: Work Posted 31/10/14 01:21 AM Share Posted 31/10/14 01:21 AM too much blackness... cant seeCatch can fitting day at Lukes house.... 1 Link to comment Share on other sites More sharing options...
Lennox Member 2,586 Member For: 11y 10m Gender: Male Location: Perth Posted 31/10/14 02:05 AM Share Posted 31/10/14 02:05 AM I am hoping to make WAW on the 26th of November if anyone is keen. I have a 400RWHP statesman to beat before I start modding mine. after that he is looking at installing a 6.2 supercharged LSA motor, and I'm looking at the usual stuff to get mine to ~380rwkw. Then we will hit the drags again. Gotta have some motivation I guess. You'll destroy him just make sure your tyres are decent Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 1m 2d Gender: Male Location: Probably above atmospheric pressure Posted 31/10/14 02:43 AM Share Posted 31/10/14 02:43 AM Anyone up for an impromptu cruise tonight?I'm home alone and either I play Alien Isolation or I go burn some hydrocarbons. Link to comment Share on other sites More sharing options...
