  • To Loud
  • Member For: 13y 5m 2d
Who want's any products from Gulf Western? I' prefer to order in one order to save stuffing my guy around,
So far Mick GeGe6 1 of Syntrans? ($125)
(Please note, I'm only acting as a middleman Im not skimming anything off the top/getting a personal discount for organising any purchases)
Ralph, I am interested in GW for my manual box. I am assuming that I can use this for my box, even though it is for autos?
What is everyone else using for their Diff oil?
Edited by masda74
  • Moar Powar Babeh
  • Member For: 19y 7m 10d
I don't know what they spec for the TR6060,
It would either be Syntrans or their low VIS gear oil
http://www.gulfwestern.com.au/Gear-Lubricants.html
  • To Loud
Fark me. the more I read, the more I get confused.
Looks like Penrite Pro Gear can be used in the gearboxes and in some Diff's.
Luke I will do some more research and then let you know. when do you plan on ordering the stuff?
  • Moar Powar Babeh
I'm in no rush as I don't actually require anything at the moment, so the collective mass will decide the right time to order.
  • Member For: 11y 11m 7d
Luke....I may as well give it a try (If you believe it is as good as ZF lIfegaurd 6 or whatever the OEM stuff is called?)
You can PM me or just answer here if you CBF....
Just want to confirm:
1) It will be fine to sit in the drum/bottle for at least another year - unopened and probably in my lounge room (or would garage be better cause cooler?)
2) Is syntrans the one I would need for my ZF 6 Speed auto?
3) You've been running this stuff haven't you? How many changes have you done?
4) What diff oil do you use? Should I just stick with Nulon?
Ok, that's all I can think of ATM hahaha
Cheers!
  • Moar Powar Babeh
Yes it will be fine to store, personally I would just buy it when you need it.
Yes.
Yes,2 changes one from LG6 @ 100kms and a second at 105k kms. Second was to ensure full flush
Have generally run Castrol in the Past, will try out the GW next.
Cheers!
Cheers Luke.....so will you be doing another lot of ordering in 12 months time? hahaha
Cause if so....I will just wait until the next one....but If this will be the last time you can be bothered doing it, then I don't want to miss out!
  • Member For: 12y 2m 7d
according to the gw website what I need is Ultra Clear Syn 85w140
1.8 litres
If that's too little to order all good I understand
Also not back for 4 weeks now so if you order before that I wont be able to pick up for a while is that ok? No worries if not.
  • Moar Powar Babeh
It will come in nominal quantities (usually 5ltrs/20ltrs and 204ltrs).
Make a deal with another member/s who need to do the same.
