  • Will do skids for food
  • Member For: 13y 8m
Squishy bushes causing toe out on braking IIRC?
I'm a real cruisey driver 99.5% of the time so I don't know it that's it.
  • skids
  • Member For: 12y 6m 6d
  • Gender: Not Telling
Everyone was accusing me of driving hard when they saw my front tyres, the passenger side has excessive wear on the outer edge, the drivers side has excessive wear on the inner edge.
Was warned upon getting wheels aligned to get a camber put put in and yeah that never occured and yep two new front tyres coming up .
  • Member For: 17y 7m 10d
Not driving it hard enough then! hahaha.
  • skids
Oh the sound it makes is just driving me absolutely nuts.
when I'm cornering left its super quiet then the noise from the front tyres is really loud when going straight or turning to the right :(
  • Member For: 19y 11m 26d
There is no real gain to be had using an external gate on the factory manifold....unless you want the screamer noise of course. I well ported internal gate can in some instances work better. I.e the older ETM 38mm external setups used a press bent screamer pipe so effectively the gate size is less than 38mm.
  • Hench, but no longer shredded or tanned.
  • Member For: 18y 3m 6d
Thanks mate. Deal fell through on the setup I was looking at anyways.
one last question. If I were to grab a gtx, can I wait untill a little further down the track to purchase the surge tank or is it highly reccomended to run one?
  • Member For: 15y 13d
A gtx will outperform your std fuel system when cranked uup.but if you go for a real conservative tune and down the track install surge and retune then should be no probs. But paying for two tunes seems silly.
  • 570Nm @1800rpm
  • Member For: 21y 9m 12d
Hi MurdoK, what wheels do you have on your car?
I am squinting at your avatar picture :)
I asked XFT this question and Simon said sorta the same as Murdok.
It can also be an issue if you get heavy footed with low fuel levels.
One of their mechs also told me separately that he would be uncomfortable at anything over 370-380 in an FG without one.
The other thing is that you wouldnt want to be strapped onto a dyno and find your fuel system can't keep up and then have to rush around trying to get something in there.
I spent the money for peace of mind and the cost of a second tune would almost cost as much as a surge tank anyway.
