  • Moar Powar Babeh
  • Member For: 19y 8m 5d
3.5" V band? Not a huge amount, It would only be a matter of loping the 5 bolt internal gate flange off the dump and replacing it with an bend with a 4" to 3.5" reducer and a 3.5" v band, of having a dump custom made. Depending on the brand opt A could turn out to the cheaper option
Why the V band housing?
  • Hench, but no longer shredded or tanned.
  • Member For: 18y 2m
Am I better off just welding my std rear housings flapper? And just utilize that instead? What gains cam I actually expect from the 1.06 opposed to the standard housing? Wasn't a matter of choice, its just what was already on it.
  • 570Nm @1800rpm
  • Member For: 21y 8m 6d
  • Get It To Wheelspin Uncontrolably Then Give It Another 5 Pounds
  • Cruise Control
  • Member For: 14y 7m 7d
  On 19/07/2013 at 9:22 AM, Boganspeed said:
Due to my wheel alignment being up to sh*t. I had to replace two front tyres today because the inside edge has worn out........................
Next week, camber kit.
ive had this 2wice on my car, and I keep my alignment pretty spot on (tyres look same as urs Phil). is it due to camber when you lower it? (although the camber always looks ok on the alignment printout).
  • Thooperrrrrrr
  • Member For: 13y 10m 26d
Cooler sold... to me.
Need to pick it up in Sinagra/Neerabup so if I don't reply later, I've been murdered.
  • Will do skids for food
  • Member For: 13y 6m 24d
I've heard two things Kyle, one is camber, the other is toe out.
My camber is really pronounced but my toe out was way off the mark when I had it rechecked.
Getting WA suspensions to fit a camber kit Saturday so that should hopefully sort it.
  • Member For: 17y 6m 4d
Squishy bushes causing toe out on braking IIRC?
  • Thooperrrrrrr
United station going up on Gnangara Road, will have E85 from what I gathered from the signs advertising it
