Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4d Gender: Male Location: Perth Posted 13/07/11 02:12 AM Share Posted 13/07/11 02:12 AM yes and or no. I couldnt get the factory 2 step exactly to my liking. Its fuel cut not spark hence no fully sik bee-r esque backfiring, but i dont have neutral rev limit hysteresis in HPT (maybe be in SCT tho?) so the difference in “on” and “off” rpm was too high IMHOIe: set is too 3500rpm and it would fluctuate between 3250 and 3500, Also fuel instead of spark cut meant less spool on the limiter (best I could get @ 3800 rpm was 10lb)The Little blue box is a spark cut setup with WOT shift ign cut so while being vicious on the Cat should give higher boost on the limiter and the WOT shift function should be good for a 10th or 2 Link to comment Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 15y 10m 2d Gender: Male Location: Perth Posted 13/07/11 02:23 AM Share Posted 13/07/11 02:23 AM fuel cut = gay.... spark cut ftw ;Dbut better than nothing I've got SCT going on the car this week, so ill explore the 2step options with that if not, it will be time to play with stuff Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4d Gender: Male Location: Perth Posted 13/07/11 02:29 AM Share Posted 13/07/11 02:29 AM Matt, In order to get the most from the factory two step you will need to either mod the clutch switch position or the reverse lockout wiring.If you dont mod the clutch switch activation point the limiter will come back on everytime you even look at the clutch pedal. If you leave this stock and mod the reverse lockout wiring so its powered by the brake light switch a 6th to 5th downshift with a small tap on the brake will open the lockout and could mean you end up trying to grab reverse Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 2m 19d Gender: Male Location: OZ Posted 13/07/11 02:34 AM Share Posted 13/07/11 02:34 AM yes and or no. I couldnt get the factory 2 step exactly to my liking. Its fuel cut not spark hence no fully sik bee-r esque backfiring, but I dont have neutral rev limit hysteresis in HPT (maybe be in SCT though?) so the difference in “on” and “off” rpm was too high IMHOIe: set is too 3500rpm and it would fluctuate between 3250 and 3500, Also fuel instead of spark cut meant less spool on the limiter (best I could get @ 3800 rpm was 10lb)The Little blue box is a spark cut setup with WOT shift ign cut so while being vicious on the Cat should give higher boost on the limiter and the WOT shift function should be good for a 10th or 2For others that don't know (luke does ), you're wasting your time with using the factory style two step....it can be done but it won't work like it does with the non-DBW cars. Plus it bounces around on the limiter too much as Luke mentioned, easier just to hold it on your desired RPM. Mine never backfired though Luke? The same problem we have with the DBW (drive by wire) falcons is experienced by the late model mustangs in the US and they use other methods such as the WOT box (they're big on 2-steps over there as all non-DBW cars can enable the factory 2-step very easily and it works flawlessly). Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4d Gender: Male Location: Perth Posted 13/07/11 02:36 AM Share Posted 13/07/11 02:36 AM backfire? Niether has mine Toads?My intention is to set the WOT Box up at <3k and use it as more of a launch assit than a true 2 step (I can't see a BA sedan driveline take a 5K 2 step launch ) Im more excited about the WOT shift function TBH Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 2m 19d Gender: Male Location: OZ Posted 13/07/11 02:39 AM Share Posted 13/07/11 02:39 AM ahhhh think I read your post wrong Make sure you get us some vids and logs! You could be onto a winner :-) Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4d Gender: Male Location: Perth Posted 13/07/11 02:42 AM Share Posted 13/07/11 02:42 AM Wot Box + Eboost overboost function + Dodgy Bros backyard tune should = bigger boost spikes on gear change than a badly tuned ZF Link to comment Share on other sites More sharing options...
Cheaty McCheats Totally not a Cop Donating Members 821 Member For: 13y 8m 2d Gender: Male Location: Melbourne Posted 13/07/11 04:25 AM Share Posted 13/07/11 04:25 AM Woo cars getting fixed up, total $9000.Looks like I'll be coming on the next cruise, providing I haven't lost my license by then. Gotta fine due on the 15th that'll put me over :( Link to comment Share on other sites More sharing options...
LOOSEBF Member 106 Member For: 16y 4m 16d Gender: Male Posted 13/07/11 04:55 AM Share Posted 13/07/11 04:55 AM Thanks to Dean for the Brembo's at mate's rates Anyone else keen on 6pot fronts, 4pot fronts or 4pot rears give me a shout. Can get goooood pricing on new Brembo's for a limited time.Hey dude, how much can you get brembos for?Got a bf ute so I think only need front? Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 10m 3d Gender: Male Location: Probably above atmospheric pressure Posted 13/07/11 06:05 AM Share Posted 13/07/11 06:05 AM I reiterate, there must be a distinct presence of BRAAPBRAPPBRAPBRAPBRAAAP at the next cruise you attend Luke hahaha. Maybe I'll see if Torquen can come along in his olive green Silvia to satisfy my limiter desire...he's probably gotten a sticker or something by now though! Link to comment Share on other sites More sharing options...
