WA Spotted & Chit Chat Thread
cunners
  • Member For: 17y 2m 18d
What's a catch can worth anyway? It stops excess oil in the intake system right, I assume it gets there from the recirculation of a bit of air?
Edit - just reading it's from the blow by oil mist venting through that little PCV tube back to the intake. Is that the same one which snapped on my car ages ago? I seem to recall mixing that up with the PCV tube though.
Edited by -SteveR-
  • Get It To Wheelspin Uncontrolably Then Give It Another 5 Pounds
  • Cruise Control
  • Member For: 14y 3m 21d
:spotted: a bunch of f6's and XR6T's going past airport hahahahaha
was fun ppls. Thanks Steve. shame about the random cyclone giving us sh*tty weather. was a good chance to test the new rubber though. till next time I guess..
lol!! Terrible luck man :( Keen to see what testing reveals.
I hosed mine down, gave it a wipe with the soapy hand cloth and dried. Couldn't leave it filthy like that!!
Wouldn't mind some gate myself but I need other things done like rear bushes. My turbo is barely holding the gases as it is, makes some odd noises at times due to the wastegate spring only barely holding it shut I think!
  • Member For: 18y 1m 18d
Would it be the crank case ventilation, with the limited mods that he has? I've never heard of the dipstick popping out before. Is this a problem you've come across before Luke?
You haven't overfilled the oil have you Grug......
  • Moar Powar Babeh
  • Member For: 19y 4m 19d
Theres a 1way valve installed in between the plenum and rocker cover. it's ment too allow crankcase gases too be drawn into the plenum under vacuum/ cruise conditions and close off under boost too prevent crankcase over pressure. if this has failed the crankcase becomes pressurised under boost and the pressure can pop out the dip stick, it also pressurises the turbo oil drain and can cause issues with lubrication/seals as the oil cannot drain out of the turbo quickly enough
Spotted NOTHING BUT BLOODY SUN today in the hills.
I say re run the map in 3 weeks or whenever rosters permit. How is February 19th for people?
