Guest Slash Guests Posted 28/01/11 04:00 AM Share Posted 28/01/11 04:00 AM (edited) Yeah Dean im 100% keen for the plates Should have just bought my ute as I said at the beginning... Would have been cheaper Old one went kaput. Mike, had a look and it looks easy enough to get off, I reckon I'd struggle to get it back on though as its a pretty tight gap.Turbo's f*cked due to blocked oil supply line as Arron has already said.Who installed the replacement turbs 12 months ago? I'd get on the phone to them & ask what the root cause of the original failure was (bet my balls it was an oil supply issue), and then ask what else they did along with replacing the turbo. If nothing, burn their shop down.Also, do not drive it until someone either checks it out or you get a new turbs. If you get a full failure, it is likely that pieces of turbo blades will be ingested by your engine & then you'll have a much bigger/more expensive problem on your hands. A $30 taxi now could save you thousands in the not too distant future Edited 28/01/11 04:01 AM by Slash Link to comment Share on other sites More sharing options...
RIP_HSV HOON Member 1,636 Member For: 14y 6m 9d Gender: Male Location: W.A Posted 28/01/11 04:06 AM Share Posted 28/01/11 04:06 AM possibly should have Dean but been through alot with the old girl Good luck with the turbo grug, as Dean said not good for a turbs under a year old lines etc should've been checked or replaced at the same time. Link to comment Share on other sites More sharing options...
RIP_HSV HOON Member 1,636 Member For: 14y 6m 9d Gender: Male Location: W.A Posted 28/01/11 04:11 AM Share Posted 28/01/11 04:11 AM Spotted this morning Purple BF ute with bars smoking it up along southern river road, had private plates but couldn't make them out with all the smoke Link to comment Share on other sites More sharing options...
Grug Member 1,318 Member For: 16y 1m 26d Posted 28/01/11 04:14 AM Share Posted 28/01/11 04:14 AM (edited) Was Ford in Wangara. Would it be okay to drive off boost? Edited 28/01/11 04:15 AM by Grug Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 1d Gender: Male Location: Perth Posted 28/01/11 04:16 AM Share Posted 28/01/11 04:16 AM WAH RAN TEE........................... Good luck tho, in my experince there a bunch of muppets and will try and pin it on your tune or some other BS And no not okay too drive off boost. Turbo is still spinning.If they wont warrant it and you have too cough up just replacing a bearing pack will be far cheaper, than a busted comp wheel, comp cover, exhaust well an possibly debris injection by the engine said.As the short man said a few $'s on taxi's could save you $$$ (or find a $300 boonga and cruise that while the phoons pharked) Link to comment Share on other sites More sharing options...
RIP_HSV HOON Member 1,636 Member For: 14y 6m 9d Gender: Male Location: W.A Posted 28/01/11 04:16 AM Share Posted 28/01/11 04:16 AM should have warranty??? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 1d Gender: Male Location: Perth Posted 28/01/11 04:23 AM Share Posted 28/01/11 04:23 AM Spotted this morning Purple BF ute with bars smoking it up along southern river road, had private plates but couldn't make them out with all the smoke Purple BF...? Link to comment Share on other sites More sharing options...
RIP_HSV HOON Member 1,636 Member For: 14y 6m 9d Gender: Male Location: W.A Posted 28/01/11 04:27 AM Share Posted 28/01/11 04:27 AM yeah looks similar to one I have seen alot of on strawberry drive in seville grove..... Link to comment Share on other sites More sharing options...
xr6t ego Member 1,112 Member For: 17y 9m Gender: Male Location: PERTH WA Posted 28/01/11 04:39 AM Share Posted 28/01/11 04:39 AM +1 for them being muppets at Wangarra Fraud!Give Simon a call, he should have some advice to give you regarding the turbs!. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 10m Gender: Male Location: Probably above atmospheric pressure Posted 28/01/11 04:59 AM Share Posted 28/01/11 04:59 AM Yeah he inspected mine and called up Titan Ford and made a recommendation. His mate in the service dept was on hols at the time anyway but they sorted it out for me. There was a mysterious delay of a week where no work was being done but I couldn't have the car which I'm dead certain was them checking the car was 100% stock. In the end it's up to the dealer and Ford to OK the warranty job no matter who calls them up and says it's farked, but thanks to Simon all the same!PS they will dump your oil if they replace it under warranty, Ford won't warrant it otherwise. Try not to go in with a fresh batch of Edge 0-40 like I did, had to argue with them about paying for the oil. In the end I let them charge for the filter only. Link to comment Share on other sites More sharing options...
