FLASHXR Donating Members 135 Member For: 19y 8m 5d Gender: Male Location: Sydney Posted 06/12/05 10:40 PM Share Posted 06/12/05 10:40 PM Anybody know if you can remove the sump off the engine in an XR6T without lifting the engine. Sounds like my next door neighbour has a little man with a hammer in his engine lol. Link to comment https://www.fordxr6turbo.com/forum/topic/21809-bottom-end-bearings/ Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 3m 3d Gender: Male Location: Sydney Posted 06/12/05 11:37 PM Share Posted 06/12/05 11:37 PM I think you will find it is a motor out jobbie. Link to comment https://www.fordxr6turbo.com/forum/topic/21809-bottom-end-bearings/#findComment-322546 Share on other sites More sharing options...
NT TURBO Member 1,128 Member For: 22y 2m 2d Gender: Male Location: Darwin NT Posted 07/12/05 03:09 AM Share Posted 07/12/05 03:09 AM Yep the front suspension drops out of the way, my sump was replaced motor remained in car. Link to comment https://www.fordxr6turbo.com/forum/topic/21809-bottom-end-bearings/#findComment-322607 Share on other sites More sharing options...
FLASHXR Donating Members 135 Member For: 19y 8m 5d Gender: Male Location: Sydney Posted 07/12/05 03:15 AM Author Share Posted 07/12/05 03:15 AM NT TURBO said: Yep the front suspension drops out of the way, my sump was replaced motor remained in car.I appreciate that NT thanks alot.Is it normally the big ends of mains that go on these? Link to comment https://www.fordxr6turbo.com/forum/topic/21809-bottom-end-bearings/#findComment-322610 Share on other sites More sharing options...
cobrav8 Member 1,969 Member For: 20y 1m 23d Gender: Male Location: New Zealand Posted 07/12/05 08:17 PM Share Posted 07/12/05 08:17 PM You might be able to get the sump off etc, but you shouldnt just be replacing either big ends or mains without checking the crank out, and I dont think a pull down through the bottom of the motor is really the way to go, if it needs doing, do it properly. Link to comment https://www.fordxr6turbo.com/forum/topic/21809-bottom-end-bearings/#findComment-322755 Share on other sites More sharing options...
philldub Member 81 Member For: 20y 8m 1d Posted 07/12/05 08:24 PM Share Posted 07/12/05 08:24 PM I reckon you have a bent conrod and its touching the side of the block as it rotates and goes past the bottom of the cylinder bore ,cant fix that with the sump off in the car Link to comment https://www.fordxr6turbo.com/forum/topic/21809-bottom-end-bearings/#findComment-322756 Share on other sites More sharing options...
ColinT Donating Members 372 Member For: 20y 3m 16d Posted 07/12/05 10:10 PM Share Posted 07/12/05 10:10 PM Want a laugh.Guy at work had to do some work under his Ford. Showed the 10yo son how the hydraulic jack works.Raised the vehicle and slid under.Took a car stand with him for safety.Positioned the car stand where he was working.Son lowers jack with him under the car.Car stand slips but stops when it hits the sump.Big dent in the sump.Climbs out from under the car.Starts the engine, clunking sound heard.Tows the car to a local garage.Not wanting to remve the engine to replace the sump.Mechanic drills holes in the sump and pulls the dent out.Bogs up the holes and sprays the sump.Good as new????????? Link to comment https://www.fordxr6turbo.com/forum/topic/21809-bottom-end-bearings/#findComment-322776 Share on other sites More sharing options...
badxr6 HEINRICH PERFORMANCE AND TUNING Donating Members 439 Member For: 21y 3m 9d Gender: Male Location: adelaide Posted 10/12/05 02:21 PM Share Posted 10/12/05 02:21 PM philldub said: I reckon you have a bent conrod and its touching the side of the block as it rotates and goes past the bottom of the cylinder bore ,cant fix that with the sump off in the carI agree Link to comment https://www.fordxr6turbo.com/forum/topic/21809-bottom-end-bearings/#findComment-323457 Share on other sites More sharing options...
FORDTECH Member 383 Member For: 21y 11m 17d Location: On the edge Posted 10/12/05 09:47 PM Share Posted 10/12/05 09:47 PM To assess the damage properly you should remove the engine.Yes you can remove the sump off the engine by removing the front end from under it but if you need to replace the bearings or anything else internally you can't remove the crankshaft that easy.All the extra time involved in removing the additional parts to facilitate crank removal in situ sort of defeats the purpose. Link to comment https://www.fordxr6turbo.com/forum/topic/21809-bottom-end-bearings/#findComment-323472 Share on other sites More sharing options...
