jordak Member 1,226 Member For: 20y 7m 26d Posted 31/05/06 03:16 AM Share Posted 31/05/06 03:16 AM Your dyno sheet reflects the power curve when held in 4th and as such does not provide any meaningful info with respect to where the peak power is reached in 1st, 2nd and 3rd gears.If you did a dyno run in second gear for example it would look alot different to the one you have posted. Link to comment Share on other sites More sharing options...
Bain Member 827 Member For: 19y 11m 7d Gender: Male Location: Melbourne Posted 31/05/06 03:18 AM Share Posted 31/05/06 03:18 AM (edited) I'd probably be changing 1-2 @ 5400 ans 2-3 @ 5500.What are your 60' times?Geea. ←From memory 2.0 and 2.1If I gun it from the traffic lights up to around 5400 I found it feels like it is losing power by then.. Could be just me though.So when I get my edit in July @ HPF, I should ask for some printouts of peak power in each gear? Edited 31/05/06 03:19 AM by Bain Link to comment Share on other sites More sharing options...
SHOCK Team Grandpa Donating Members 1,921 Member For: 18y 9m 5d Gender: Male Location: Hunter Valley Posted 31/05/06 06:57 AM Share Posted 31/05/06 06:57 AM (edited) Bain, is your sedan stock.?You have similar grunt to me (196)but I have the 6s auto. Im looking for this sort of time or better in a ute, and the cash is mine. Edited 31/05/06 06:58 AM by SHOCKXR6T Link to comment Share on other sites More sharing options...
Bain Member 827 Member For: 19y 11m 7d Gender: Male Location: Melbourne Posted 31/05/06 07:31 AM Share Posted 31/05/06 07:31 AM Bain, is your sedan stock.?You have similar grunt to me (196)but I have the 6s auto. Im looking for this sort of time or better in a ute, and the cash is mine.←Was stock when I ran it. Now its got a 2nd cai and middle muffler swapped out to 2 hotdogs.None of the above though would do squat at the wheels.. Link to comment Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 1m 20d Gender: Male Location: Strapped in and holding on Posted 01/06/06 12:56 AM Share Posted 01/06/06 12:56 AM UpdateF6 Tornado 6spd968's, exhaust, actuator313rwkw, mods unchanged from last time11.87 @ 115mph1.80 60'MT'sKwinana 14deg Link to comment Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 1m 20d Gender: Male Location: Strapped in and holding on Posted 01/06/06 12:58 AM Share Posted 01/06/06 12:58 AM After looking at the dyno figures am I changing gears to late? Usually I would change at 5100 - 5200 rpm... Should I be changing at 5000rpm just after my peak kw or even sooner?←Change just after peak torque, forget peak power.. Link to comment Share on other sites More sharing options...
geea Site protagonist Lifetime Members 4,320 Member For: 21y 8m 24d Gender: Male Location: At the lights, waiting for you. Posted 01/06/06 01:47 AM Author Share Posted 01/06/06 01:47 AM UpdateF6 Tornado 6spd968's, exhaust, actuator313rwkw, mods unchanged from last time11.87 @ 115mph1.80 60'MT'sKwinana 14deg←that's a great effort in a manual.Geea. Link to comment Share on other sites More sharing options...
dat_40l Donating Members 997 Member For: 19y 7m 15d Gender: Male Location: newcastle NSW Posted 01/06/06 04:49 AM Share Posted 01/06/06 04:49 AM 13.81 with just a cooler and k&n with the 5spd manual last night at wsid Link to comment Share on other sites More sharing options...
SHOCK Team Grandpa Donating Members 1,921 Member For: 18y 9m 5d Gender: Male Location: Hunter Valley Posted 03/06/06 12:02 PM Share Posted 03/06/06 12:02 PM First run - 14.162@99.47 with 2.20 60ftSecond run - 14.284@100.56 with 2.298 60ftWon the money$$$$$$ Link to comment Share on other sites More sharing options...
blueboost Member 1,204 Member For: 20y 8m 9d Gender: Male Location: Mackay NorthQueensland Posted 25/06/06 11:41 AM Share Posted 25/06/06 11:41 AM ran my xr6t on the weekend, for the first time, with its Nizpro kit,the car has a stock auto, I have put the standed stall back in, the car had a full fuel tank,was running on 95 octane unleaded, (that's all we can get in Mackay NorthQueensland)running on m/t street radialstrack temp at time of run was 26Degrees 66% humiditynew pb 11.59 @120 mph 1.70 60 ft (must have streched the standed stall a bit)I did run it up on a Dyno with this tune, but if you want, post what rwks, and NM you think it would have had to run that time and that mph, I just thought it would be good to see peoples estimates,I should just tell you I have kept a fair bit of power out of it under 4500, so that when I hit the next gear, it would not spray the gear box all over the trackand also because it is standed internals, so it did not squash the rods,also the run was in 2nd gear, I have to go until tomorow night, so guess away and I will see how close we can get. David Link to comment Share on other sites More sharing options...
