Quarter Mile Times Discussion
geea
  • 2 months later...
  • 2 weeks later...
  • Site protagonist
  • Member For: 21y 8m 24d
Hi guys I was just wondering how much fuel you have in the tank and what times you are running before you need a pump upgrade.
  Thanks Chris
Ideally if you change your injectors it's wise to upgrade your fuel pump. The stock one is good for around 250rwkw's but will also deteriate over time. For lower powered cars (under300rwkw's) an upgraded intank should do the job. For those with more extensive mods I'd suggest an inline pump in conjunction with the intank pump. If funds permit I'd recommend a surge tank too. If you're planning on 325rwkw's+ I'd definately get the surge tank.
My set up is stock intank pump with a 2lt surgetank mounted on the passenger side rail under where the passengers feet would go. I have an 800hp Bosch fuel pump mouned on the surge tank feeding the fuel rail.
Geea. :glad:
  • 2 weeks later...
  • Site protagonist
what would a stock xr6t generally run?
On average low 14's. Some good ones well driven have run high 13's. I think with the 6speed auto we'll see more stock "T's" in the 13's.
Geea. :blink:
  • Team Grandpa
  • Member For: 18y 9m 5d
Geea. :spoton:
Hope you are right champ :crybaby:
  • Member For: 19y 11m 7d
Quick question.
I had my car dyno'd on the weekend.
My previous times have been all around 14.01 - 14.2 @ 100 - 102mph
After looking at the dyno figures am I changing gears to late? Usually I would change at 5100 - 5200 rpm... Should I be changing at 5000rpm just after my peak kw or even sooner?
Heres the dyno print out.
  • Site protagonist
Quick question.
<div class='bbimg'>
</div>
I'd probably be changing 1-2 @ 5400 ans 2-3 @ 5500.
What are your 60' times?
Geea. :spoton:
