ugy Donating Members 199 Member For: 19y 7m 8d Location: Auckland Posted 06/12/05 04:03 AM Share Posted 06/12/05 04:03 AM Regapped the plugs today to .98 and seem to have aquired a s..t load of stonk down low.Am I dreaming or has anybody else noticed this that has done theirs? Link to comment https://www.fordxr6turbo.com/forum/topic/21787-regapped-plugs/ Share on other sites More sharing options...
blueboost Member 1,204 Member For: 21y 2d Gender: Male Location: Mackay NorthQueensland Posted 06/12/05 09:43 AM Share Posted 06/12/05 09:43 AM I did not get any inprovement when I gaped mine, but if your plugs were missfiring, it is possible to pick up a bit of power. Link to comment https://www.fordxr6turbo.com/forum/topic/21787-regapped-plugs/#findComment-322428 Share on other sites More sharing options...
bugster70 Donating Members 1,326 Member For: 20y 26d Location: Canberra Posted 06/12/05 10:35 PM Share Posted 06/12/05 10:35 PM ugy, do you mean 0.89 and not 0.98? As blueboost says, there is no reason why you should get more power by regapping your plugs to a smaller gap unless your plugs were misfiring/blowing out due to increased boost in the first place. Theoretically, the wider the gap the better the flame front/ignition of fuel/air mixture and the better power you should make. On a stock car there should be no reason to regap the plugs. Have you had any mods done to yours? Link to comment https://www.fordxr6turbo.com/forum/topic/21787-regapped-plugs/#findComment-322531 Share on other sites More sharing options...
ugy Donating Members 199 Member For: 19y 7m 8d Location: Auckland Posted 07/12/05 01:52 AM Author Share Posted 07/12/05 01:52 AM bugster70 said: ugy, do you mean 0.89 and not 0.98? As blueboost says, there is no reason why you should get more power by regapping your plugs to a smaller gap unless your plugs were misfiring/blowing out due to increased boost in the first place. Theoretically, the wider the gap the better the flame front/ignition of fuel/air mixture and the better power you should make. On a stock car there should be no reason to regap the plugs. Have you had any mods done to yours?<{POST_SNAPBACK}>Hi, yea I meant 0.89. I did not notice any misfiring but it seems to boost a lot quicker when you take off. I have a few mods. Capa flasher and custom tune, centre muffler removed with just straight pipes CAI. K&N. IC, and Injectors 285rw. Running 12-13 psi Link to comment https://www.fordxr6turbo.com/forum/topic/21787-regapped-plugs/#findComment-322577 Share on other sites More sharing options...
bugster70 Donating Members 1,326 Member For: 20y 26d Location: Canberra Posted 07/12/05 02:59 AM Share Posted 07/12/05 02:59 AM ugy said: Capa flasher and custom tune ... running 12-13 psi And there's your reason why regapping your plugs gave you more power. I'm very surprised that with that much boost your car wasn't running really badly without regapping your plugs!! Regapping plugs is simply a must when you increase boost to those sorts of levels, I'm also surprised your tuner didn't make that abundantly clear to you. Link to comment https://www.fordxr6turbo.com/forum/topic/21787-regapped-plugs/#findComment-322602 Share on other sites More sharing options...
ugy Donating Members 199 Member For: 19y 7m 8d Location: Auckland Posted 07/12/05 04:11 AM Author Share Posted 07/12/05 04:11 AM bugster70 said: ugy said: Capa flasher and custom tune ... running 12-13 psi <{POST_SNAPBACK}>And there's your reason why regapping your plugs gave you more power. I'm very surprised that with that much boost your car wasn't running really badly without regapping your plugs!! Regapping plugs is simply a must when you increase boost to those sorts of levels, I'm also surprised your tuner didn't make that abundantly clear to you.<{POST_SNAPBACK}>Thanks for that, I am sure I'm making more power. You learn something every day on here. Link to comment https://www.fordxr6turbo.com/forum/topic/21787-regapped-plugs/#findComment-322625 Share on other sites More sharing options...
