Max Power Member 381 Member For: 20y 8m 4d Location: MENAI, NSW Posted 28/03/06 08:07 AM Share Posted 28/03/06 08:07 AM (edited) ....Because you can't flat change a manual XR6T.....<{POST_SNAPBACK}>Why not?<{POST_SNAPBACK}>Yeah, why not?<{POST_SNAPBACK}>No reason why you cant jetute. I thought about it a while back and started practicing. The hurdle I had to get over was to train myself not to lift off the gas pedal at all when I clutch in. I flat change now whenever I want with no probs. Im pretty sure that Ive got it down so Im not bouncing off the rev limit also. Now to practice this on the strip.Back on topic: I dont think that flat changing will get you into 11's without huge power.Regards,Arthur Edited 28/03/06 08:10 AM by Max Power Link to comment Share on other sites More sharing options...
jetute Donating Members 4,553 Member For: 20y 11m 6d Gender: Male Location: brisbane Posted 28/03/06 08:12 AM Share Posted 28/03/06 08:12 AM ....Because you can't flat change a manual XR6T.....Why not?Yeah, why not?No reason why you cant jetute. I thought about it a while back and started practicing. The hurdle I had to get over was to train myself not to lift off the gas pedal at all when I clutch in. I flat change now whenever I want with no probs. Im pretty sure that Ive got it down so Im not bouncing off the rev limit also. Now to practice this on the strip.Back on topic: I dont think that flat changing will get you into 11's without huge power.Regards,Arthurwell done... and surely a there must a function in the capa software that can make the flat change a much refined function in the hands of a tuner who knows how to worktyhe function?? Link to comment Share on other sites More sharing options...
summoner Member 288 Member For: 19y 5m 2d Posted 28/03/06 04:17 PM Share Posted 28/03/06 04:17 PM Well once clutch is done I'm going to give it a go with some sticky tyres. I think there are a few of us out there trying to get into the 11's now :D Link to comment Share on other sites More sharing options...
on_b000st Member 9 Member For: 18y 10m Location: NSW - Outer West Posted 30/03/06 04:15 AM Share Posted 30/03/06 04:15 AM Roll ons??Flat change??If u dont mind me asking, im clueless as to what these terms relate to...can someone please explain? Link to comment Share on other sites More sharing options...
iTec TEAM BA Donating Members 1,755 Member For: 20y 30d Gender: Male Location: North of The Bridge Posted 30/03/06 04:27 AM Share Posted 30/03/06 04:27 AM Roll ons??Flat change??If u dont mind me asking, im clueless as to what these terms relate to...can someone please explain?roll ons are a drag race from a rolling start, ie going up the freeway, more of a real world drag.flat changeing is when you change gears in a manual without backing of the throttle as you would normally do. Link to comment Share on other sites More sharing options...
cobrav8 Member 1,969 Member For: 19y 9m 14d Gender: Male Location: New Zealand Posted 30/03/06 10:02 PM Share Posted 30/03/06 10:02 PM What would happen if you disconnected the switch on the clutch pedal? Ie so the computer didnt know that you had engaged the clutch. Could this allow the ECU to leave boost alone (and it would drop a bit anyway as you lift of the throttle?).I have wondered about this before relating to the cruise control, ie if you are in 4th or 5th and want to change to maintain speed - then it would be good if the cruise control wasnt disabled as you change.Anyway - what will happen if you disconnect this - and what are the side effects? Link to comment Share on other sites More sharing options...
geea Site protagonist Lifetime Members 4,320 Member For: 21y 7m 26d Gender: Male Location: At the lights, waiting for you. Posted 31/03/06 01:46 AM Share Posted 31/03/06 01:46 AM What would happen if you disconnected the switch on the clutch pedal? Ie so the computer didnt know that you had engaged the clutch. Could this allow the ECU to leave boost alone (and it would drop a bit anyway as you lift of the throttle?).I have wondered about this before relating to the cruise control, ie if you are in 4th or 5th and want to change to maintain speed - then it would be good if the cruise control wasnt disabled as you change.Anyway - what will happen if you disconnect this - and what are the side effects?<{POST_SNAPBACK}>I think there is more to it than just the switch on the clutch. Possibly load and torque settings. Hopefully Martin or someone else with a better understanding of the edit could shed a little light on this. Geea. Link to comment Share on other sites More sharing options...
Led Ft Donating Members 112 Member For: 16y 11m 18d Gender: Male Location: Gladstone Posted 21/01/08 09:31 AM Share Posted 21/01/08 09:31 AM hey im going to give it a shot at the next test and tune I think I may run 11.5 semi slicks manual t ute 438.4rwhp Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 5m 30d Gender: Male Location: OZ Posted 21/01/08 09:51 AM Share Posted 21/01/08 09:51 AM 11.50....absolutely no chance with that power, sorry harsh but true. I've watched enough 11 second attempt to know that power isn't everything, but that simply isn't enough. Link to comment Share on other sites More sharing options...
Led Ft Donating Members 112 Member For: 16y 11m 18d Gender: Male Location: Gladstone Posted 21/01/08 10:02 AM Share Posted 21/01/08 10:02 AM (edited) 11.50....absolutely no chance with that power, sorry harsh but true. I've watched enough 11 second attempt to know that power isn't everything, but that simply isn't enough.wat sort of power you thinkin then.. and wat do you think ill run with that power? Edited 21/01/08 10:03 AM by phat6 Link to comment Share on other sites More sharing options...
