wild4d Member 23 Member For: 19y 4m 13d Posted 29/11/05 07:26 AM Share Posted 29/11/05 07:26 AM I noticed a sudden drop in psi when driving my T. I don't know what it is but when I put the foot down I can definetly notice a big diference in that kick you normally get when boost kicks in. So it feels like its on lower boost.has this happend to anyone or anyone know what it might be??? Link to comment Share on other sites More sharing options...
BAturb Member 521 Member For: 20y 2m 17d Gender: Male Location: Adelaide Posted 29/11/05 07:33 AM Share Posted 29/11/05 07:33 AM check your hoses, might have blown one off Link to comment Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 1m 15d Gender: Male Location: Strapped in and holding on Posted 29/11/05 08:13 AM Share Posted 29/11/05 08:13 AM Loose manifold bolts.. Where the turbo meets tha manifold??I have one missing and 2 loose, BIG difference in power.. Link to comment Share on other sites More sharing options...
Jamie XR6 Member 190 Member For: 21y 9m 26d Location: Sydney Posted 29/11/05 09:46 AM Share Posted 29/11/05 09:46 AM I've had similar happen to me twice. The first time the turbo heat melted the VCT sensor wiring and the second time I blew the air intake to the turbo off. Link to comment Share on other sites More sharing options...
BALLBREAKER Member 427 Member For: 19y 7m 11d Gender: Male Posted 29/11/05 11:38 AM Share Posted 29/11/05 11:38 AM Still keep checkin' for ken24's dik<{POST_SNAPBACK}>If all your pips are tight . Start un bolting zost manifold 2 check turbo bolt my old XR6 T only had 2 bolts result had low boost.Its a *beep* of a job. Link to comment Share on other sites More sharing options...
benmwhite Donating Members 143 Member For: 20y 8m 5d Gender: Male Location: Toowoomba Posted 29/11/05 12:20 PM Share Posted 29/11/05 12:20 PM Just had this happen too - there was an e-clip fixing the wastegate actuator in place under the dump pipe - after it came loose - no boost.... a real bugger to get to, so try all your plumbing first.... good luck!!! Link to comment Share on other sites More sharing options...
BlueXR6Turbo The Best Member Donating Members 1,970 Member For: 22y 21d Gender: Male Location: Adelaide Posted 29/11/05 12:29 PM Share Posted 29/11/05 12:29 PM Same thing happened to mine. They ended up having to replace the PCM. Link to comment Share on other sites More sharing options...
wild4d Member 23 Member For: 19y 4m 13d Posted 30/11/05 04:04 AM Author Share Posted 30/11/05 04:04 AM thanks fellas I'll check what I can on my own. Eventhough its still under warranty Link to comment Share on other sites More sharing options...
