tur Flight 6 Member 471 Member For: 21y 6m 3d Posted 27/11/05 06:38 AM Share Posted 27/11/05 06:38 AM (edited) Hey just had nizpro tune my car. I got the cobra valve springs and Edit done.Car made 210rwkw on 4.5 to 5 psi Stock269 rwkw on 9 psi. Simon said its a very good engine, he said we usually get them making that power at 12-13psi. He then put it back to 260rwkw.Car has Standard Injectors. and standard exhaust.Good job Nizpro. Edited 27/11/05 06:39 AM by tur Link to comment Share on other sites More sharing options...
shockwavexr6t Member 50 Member For: 19y 10m 4d Posted 27/11/05 06:45 AM Share Posted 27/11/05 06:45 AM great results tur and well done nizpro it will be interesting when you get your injectors done.cheersps enjoy the new found power Link to comment Share on other sites More sharing options...
RAPHOON Donating Members 1,776 Member For: 21y 7m 11d Posted 27/11/05 06:47 AM Share Posted 27/11/05 06:47 AM Excellent results!It wasn't long ago when these sort of power levels at safe AFR's were thought to be impossible on standard injectors.Well done Tur and Nizpro! Link to comment Share on other sites More sharing options...
XRT8U Member 503 Member For: 20y 6m 9d Gender: Male Location: Melbourne Posted 27/11/05 06:52 AM Share Posted 27/11/05 06:52 AM is yours auto or manual tur? Link to comment Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 1m 14d Gender: Male Location: Sydney Posted 27/11/05 06:59 AM Share Posted 27/11/05 06:59 AM Very good result.I was there at Nizpro all day Friday.I saw a stock standard 5-speed sedan have the Edit installed, new plugs plus valve springs done.Then watched Dave tune, he selected the custom base Nizpro map to correctly match the ecu version, then load the map.1st run it made over 260rwkw on 9lb, and didn't need much fine tuning after that.That was about the power level that the owner wanted, and he didn't want any more, as he was concerned about his gearbox.A second lower power map was established.Some cars seem to be easy to tune, but others are more troublesome.This was a very good one.The slowest part about Edit tuning is the uploading/downloading of the program through the very slow serial interface.Anyway, great result.Brian Link to comment Share on other sites More sharing options...
dingah2 Crusty aviator Member 846 Member For: 20y 7m 19d Gender: Male Location: ACT Posted 27/11/05 07:20 AM Share Posted 27/11/05 07:20 AM I too watched both Dave and Simon throughout the day I was there with both temperamental and easy tunes they always appear to get a result worthy of their reputation. I'll be back early next year to fnish off mine with some new springs and an I/c.Dingah Link to comment Share on other sites More sharing options...
tur Flight 6 Member 471 Member For: 21y 6m 3d Posted 27/11/05 09:00 AM Author Share Posted 27/11/05 09:00 AM cars manual t5. Link to comment Share on other sites More sharing options...
drcook Member 752 Member For: 20y 5m 19d Location: leonay Posted 28/11/05 12:18 AM Share Posted 28/11/05 12:18 AM where is nizpro? Link to comment Share on other sites More sharing options...
Flukey Seriously Flukey Member Donating Members 4,354 Member For: 20y 10m 17d Gender: Male Location: Melbourne Posted 28/11/05 12:25 AM Share Posted 28/11/05 12:25 AM Bayswater in Melbourne Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 9m 12d Gender: Male Location: Victoria Posted 30/11/05 08:07 AM Share Posted 30/11/05 08:07 AM I was there on Monday to get a SMB dump pipe and cat fitted.Went from 260rwkw's @ 4800-4900 rpm to 286rwkw's @ 4600-4700 rpm. Much better mid and high range power. Link to comment Share on other sites More sharing options...
