replicant Member 180 Member For: 19y 2m 18d Posted 09/11/05 01:28 AM Share Posted 09/11/05 01:28 AM Traction control is there for a reason - it helps minimise wheelspin. At least in a Ford you can turn it off (you can turn TC 'off' in a Merc... well the switch says it's off but granny comes and stops the fun if you really stomp on it... as it is never totally OFF in a Merc).The TC works on rotation rates and will sense an individual wheels rate compared to the other driven wheel and perhaps an undriven wheel. It will allow a certain degree of slippage before intervening... intervention in the form of either activating the brake for the slipping driven wheel initially and then resorting to retarding the ignition or at the very most cutting off the fuel injector cycle. I think the Bosch 8 DSC tries to avoid using the electronic throttle control (ETC) in the Falcon installation except as a last resort because it affects throttle response.TC usually uses the ABS sensors to detect wheel rotation so most bits are already included just need a brain and a suitable connection/programming to connect to the engine management system.DSC is the evolution of TC and using some other sensors including steering angle, throttle position, yaw etc can detect either understeer or oversteer. It usually brakes one or more wheels to counteract the unwanted yaw forces. It won't save you in the event you do something really silly but in marginal situations may assist a driver in maintaining control. Try doing circle work in an AWD Territory in a snowed/iced over ski field carpark with the DSC on and then off to get an idea of how much difference it can make. And you can always turn it off - sometimes when you on sand you might want the whole system OFF no TC no DSC OR if you want to take full control and not have the electronic granny look after you. On the other hand, in the wet unless you're on a track I usually have it ON!TC/DSC self check happens at start up. Link to comment Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 1m 12d Gender: Male Location: Strapped in and holding on Posted 09/11/05 07:13 AM Share Posted 09/11/05 07:13 AM an even better test - do a circle in the carpark - and go as fast as you can with TC on - then turn it off! See if you can cause the car to break traction that way as well. <{POST_SNAPBACK}>Noooo, I bet he'll understeer the big girl into a kerb b4 the back end breakes out!!btw, I get intermittant traction control in the ute. When SWMBO is in the passenger seat and the back wheels chirp, I get a thump on the arm.... Makes for a very peacfull trip ) Link to comment Share on other sites More sharing options...
jetute Donating Members 4,553 Member For: 20y 11m 26d Gender: Male Location: brisbane Posted 09/11/05 07:21 AM Share Posted 09/11/05 07:21 AM an even better test - do a circle in the carpark - and go as fast as you can with TC on - then turn it off! See if you can cause the car to break traction that way as well. Noooo, I bet he'll understeer the big girl into a kerb b4 the back end breakes out!!btw, I get intermittant traction control in the ute. When SWMBO is in the passenger seat and the back wheels chirp, I get a thump on the arm.... Makes for a very peacfull trip ) I know that feeling.... silent treatment till arrival Link to comment Share on other sites More sharing options...
RAPHOON Donating Members 1,776 Member For: 21y 7m Posted 09/11/05 10:43 AM Share Posted 09/11/05 10:43 AM an even better test - do a circle in the carpark - and go as fast as you can with TC on - then turn it off! See if you can cause the car to break traction that way as well. Noooo, I bet he'll understeer the big girl into a kerb b4 the back end breakes out!!btw, I get intermittant traction control in the ute. When SWMBO is in the passenger seat and the back wheels chirp, I get a thump on the arm.... Makes for a very peacfull trip :o) I know that feeling.... silent treatment till arrival SWMBO. Also known as handbrake. Link to comment Share on other sites More sharing options...
xxr64t XXR.64T Donating Members 560 Member For: 19y 7m 25d Gender: Male Location: sydney's east!!! Posted 09/11/05 12:02 PM Share Posted 09/11/05 12:02 PM with TC turned off u can do the following with ease. burnouts, drift, fishies, etc. With TC on u cant do any of it as good with it off. It just takes away the reason y u get a rear wheel drive car. Just makes it more reason to enjoy the journey from a to b with an elemt of suprise. Link to comment Share on other sites More sharing options...
EvilDaifu Cruise Whore Moderating Team 5,130 Member For: 19y 5m 22d Gender: Male Location: Melbourne Posted 09/11/05 01:42 PM Share Posted 09/11/05 01:42 PM Hi, I tried out the DSC/TC in my new BF XR6T today (just got it today) not on purpose. I was still getting used to the lift off from a standing start and must have had some wheels slip on the tram tracks. She started to swerve a bit, but corrected herself real fast. Never felt I was out of control - in fact, I just kept my foot planted on the accelerator and she straightened up and I was looking at the rest of the cars in my rear view mirror... Link to comment Share on other sites More sharing options...
Rik_Biel Bionic Bealie Member 271 Member For: 21y 4m 19d Location: Perth West Oz Posted 10/11/05 05:41 AM Share Posted 10/11/05 05:41 AM Mine certainly works - and I don't like it.It was wet the other day and I thought I would test it - just a take off from a stop sign, turning left.Gunned the pedal and as soon as it started to bite the throttle cut off.Very unpleasant feeling - like the car dies.I'm driving my car nicely as it's a new one, so I have left it on as I'm not driving in a way that it will engage - but it's not a feature I like that's for sure. Link to comment Share on other sites More sharing options...
