W.a Gets Wogged.
F6 UTE
  • Member For: 20y 11m 25d
ive got my wog tune... would love to go for a drive in an extreme f6 tune one day.... maybe rapid f6 will take me for a spin one day??hint hint!!
  • Replies 192
Posted Images
  • Member For: 20y 23d
Seriously, why spend $800 - $1000 on a tuning box, another $200 to $???? on custom tuning, and then add an adjustable boost controller?
Technically, once the tune is set for a boost level and AFR's are adjusted for the desired boost level, altering the boost level from that point will cause the mixtures to become leaner or richer.
The SCT software does fuel mapping from TPS counts, not MAP. Therefore, increasing boost from the original tune will lean the mixture, reducing it will richen it up.
Isn't the point of having 3 slots to run 3 different tunes?
  • - Track Bound EVO III -
  • Member For: 20y 1m 11d
good to hear some honesty!
what other benefits and disadvantages ben?
you still got the dynosheet?
post it!!!
<{POST_SNAPBACK}>
Other benefits.... Oh, your tunes don't have the 'dicky clicky solanoid', but your tunes have a 'dicky 2000 rpm glitchy'. get your updated software happening, or get Extreme to tell u what your doing wrong!!
Disadvantages- Hell, I dunno what slot to run around in every day!!!!!!!!!!!!
Pair of Bastids, both of u.......
Yes to the graph..
  • Moar Powar Babeh
  • Member For: 19y 4m 3d
<{POST_SNAPBACK}>
who said anything about increaseing the boost beyond the level that the afr's are set to in the custom tune...? im talking about dropping the boost down to get traction off the line then bringing it back up to the max level the tune is set for...can u set the sct software to run lower boost based on time or engine rpm then increase it to the preset max level?
EDIT: APOLOGIES... this thread isnt about debating adjustable boost controllers vs three preset maps...if anybody wants to discuss this we should start a new thread....my bad... :blush:
Edited by Lucus1
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
Not from the method you suggested, however there are other ways to control torque outputs and throttle control that are gear dependant.
All this can be done via the SCT software. Launch control and torque capping relative to rpm and gearing has been around for years with the LS1 tuning software.
Edited by M6 XR6T
<{POST_SNAPBACK}>
Jason. As I mentioned, power delivery on the two different tunes come on so differently it's not funny. This I like, 3 slots are a good idea. Maybe I wanted to run a 95 RON tune because I don't think the 98 over here is any good??
Then I'd slip to the drags, fill up with 98 or Octane booster and drag away??
Yes, raising the boost will in fact screw around with afr's. Wog wanted the controller on the dyno to adjust afr's whilst he could, not to slap on after.
I would at the very least run an EBC so I could switch it off to run the Extreme tune, and have no dramas or, I'd slip over to Simons, and get him to fiddle with new found boost control aswell..
F6 map doesn't have the same control as XR6T map, ask Barry Batten, he had issues with Gregs' ( F6 map ) aswell, hence why he ran an XR6T map to get better results..
Everyone has issues with it..
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
True, but Barry didn't have revision J of the software when he worked on Greg's ute a couple of weeks ago. It's available now...I have it.
Maybe Barry can have another go at no cost to Greg if that's what they want to organise.
  • Moar Powar Babeh
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
what other ways? can u elaborate?
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
I'll check and let you know ;)
<{POST_SNAPBACK}>
yes to rpm but time huh?
you can have different max torque for every gear to a save the box or get traction!!! lowering boost will ritchen mixtures to the point of possibly fouling platinum/iridium plugs reasonably easy giving you a (what everyone else calls a lifter pumpup due to valve spring issue) miss at idle
