Thermo Fan Recommendations
Dannopower
  • Team Bute
  • Member For: 21y 6m 19d
So I guess you've reversed polarity on fan to blow air, rather than suck?
Is this the case?
And you no longer use the radiator trans cooling tank?
Only other suggestion / concern...
How much turbulence is there in the vicinity of the installation from incoming air from front grill/headlight etc etc.
Probably being pedantic, but a shroud to maximise air flow through the cooler would be much more efficient. (could use a smaller - [quiet] fan )
And why are you using water temp thermo fan control for the trans cooler anyway?
I'd be using a thermal switch on the incoming trans line to stabilise trans oil temp, independant of water temp.
Just my opinion.
At the end of the day, if you are happy with the results. that's all that counts.
cheers
tom
:spoton:
  • Replies 31
  • Member For: 19y 7m 28d
Is this the case?
Just my opinion.
cheers
tom
:crybaby:
Thanks for your input Tom.
The transmission fluid flows thru the radiator before it is air cooled.
This will at least raise the transmission fluid temperature for the climate I live in (Canberra, bloody cold most of the year!) when first driving the car.
This car is my daily driver, and gets driven around to work at times such as 6am. Under colder weather conditions there is no need for any of the thermo fans to activate, so they dont.
One reason that Ford run the fluid thru the radiator is to also HEAT the fluid for colder temperatures. Ideally, Im using the transmission air cooler and thermo fan to assist in the cooling of the gearbox under high temperature situations.
There isnt a great deal of room left anywhere to mount this since I have an aftermarket Intercooler that takes all of the front grill area. The reason it is where it is, is because there was enough room to fit it and the fan to circulate the air that comes in the openings of the lower grill. An air intake pipe of some description would probably be helpful, but im not sure where from in order to keep mud and water off the thermo fan and tranny cooler itself. It would be helpful though.
The idea of using the thermo fans linked to the radiator fans is purely so I know when they are on or off, and can activate themselves when the entire engine is hot. Since the tranny fluid in the radiator heats the radiator fluid up when its hot anyway, even though the radiator fluid is running thru a 160 degree thermostat. The cooler the radiator fluid around hot tranny fluid the better. The idea is designed to assist the entire engine and associated systems to cool down.
As we all know, heat is as big as enemy to our cars as HSV is! We want to blow away both of these enemy's! And it seems to be working!!!!
