Dannopower Donating Members 421 Member For: 19y 7m 28d Gender: Male Location: Canberra ACT Posted 05/11/05 07:41 AM Author Share Posted 05/11/05 07:41 AM http://www.daviescraig.com.au/main/fans.asp?action=model check this one out. I'l be fitting one of these..They are the push on type of cooler, from what I have been told the cooler needs to have threaded pipe fittings,not just cut the trany cooer pipe and slip on 2 hose clamps due to pressures in the line.RobIts all good, I already have the tranny cooler fitted. Its a PWR one.Im just looking for a thermo fan to fit to it when I move it from the front grille area?The little Davies Craig one looks the goods! Link to comment Share on other sites More sharing options...
Dannopower Donating Members 421 Member For: 19y 7m 28d Gender: Male Location: Canberra ACT Posted 05/11/05 07:46 AM Author Share Posted 05/11/05 07:46 AM (edited) my cooler is 195mm by 280mm. I reckon it will be perfect. how good are you with electric wiring. I spoke to simon from extreme ford tuning about running a signal wire from the existing fan wiring and he seems to think that the fan two speed settings is done using varible voltage to alter the fan speed. im hoping to pick up dcsl8 on monday and have a go at wiring it in. I'l put a temp gun on the cooler to check the cut in and out temps to prevent overheating(I dont think that'l be a problem with the bigger cooler) and over cooling with the fan if I have a win I'l take some pictures and fill ya in..... So do you think as the existing thermos have an existing variable voltage setting, it will stuff up the Davies Craig fan motor if its wired in to the existing thermo fan line? It would be really easy if it was ok to run it with the existing fans.Or are you going to wire it separately?? If so how will you control its activation?Oh, and as for the cooler itself, its fitted into the existing piping with Dash 6 fittings and braided lines, so it will take up to 200psi!!!! Not that it will ever get that much pressure, but I dont like hose clamps much! Edited 05/11/05 07:48 AM by Dannopower Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 11d Gender: Male Location: Perth Posted 05/11/05 07:49 AM Share Posted 05/11/05 07:49 AM have u moved the cooler yet danno any chance of some pics? when u mount the fan dont use those crappy cable ties that the give u to feed throught the cooler core there good for rubbing through the core and not much else.... Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 11d Gender: Male Location: Perth Posted 05/11/05 07:52 AM Share Posted 05/11/05 07:52 AM to control mine seperatly i can just put a t piece in the hot hose and run a thermo switch to run the relay control circuit. u could probably do the same thing did u use jic fittings? if you did you would be able to buy a jic t piece and use the tee port on the t piece the mount the switch Link to comment Share on other sites More sharing options...
Dannopower Donating Members 421 Member For: 19y 7m 28d Gender: Male Location: Canberra ACT Posted 05/11/05 08:04 AM Author Share Posted 05/11/05 08:04 AM have u moved the cooler yet danno any chance of some pics? when u mount the fan dont use those crappy cable ties that the give u to feed throught the cooler core there good for rubbing through the core and not much else....Check this thread-http://www.fordxr6turbo.com/forum/index.ph...topic=19147&hl=But now I will move it to under the guard like you already have Link to comment Share on other sites More sharing options...
Dannopower Donating Members 421 Member For: 19y 7m 28d Gender: Male Location: Canberra ACT Posted 05/11/05 08:11 AM Author Share Posted 05/11/05 08:11 AM So are you saying you can buy a thermo activated switch to plumb into the hose line that will turn the fan??? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 11d Gender: Male Location: Perth Posted 05/11/05 08:16 AM Share Posted 05/11/05 08:16 AM the switch is used to turn the relay for the fan on and off. i dont want to go down this path if i can wire the relay into the factory wiring. davies craig sell the switched or vdo make them as well Link to comment Share on other sites More sharing options...
Dannopower Donating Members 421 Member For: 19y 7m 28d Gender: Male Location: Canberra ACT Posted 05/11/05 08:18 AM Author Share Posted 05/11/05 08:18 AM Cheers mate, sounds like we are going down the same path the same way. Ill do it only if the factory wiring wont work. Link to comment Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 4m 25d Gender: Male Location: Mildura Posted 05/11/05 09:31 AM Share Posted 05/11/05 09:31 AM dont bother with davies craig fans.... their WAY WAY WAY overpriced!!! decent gear but nothing special, many other brands out there that do the same job. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 11d Gender: Male Location: Perth Posted 06/11/05 04:04 AM Share Posted 06/11/05 04:04 AM dont bother with davies craig fans.... their WAY WAY WAY overpriced!!! decent gear but nothing special, many other brands out there that do the same job.<{POST_SNAPBACK}>im going davies craig because ive used them before and found there good quailty. the dcsl8 retails for $100. i can get it for 40% off from conventrys Link to comment Share on other sites More sharing options...
