NT TURBO Member 1,128 Member For: 22y 2m 5d Gender: Male Location: Darwin NT Posted 27/10/05 06:13 AM Share Posted 27/10/05 06:13 AM I have a basic network at home, one pc connected to adsl usb modem other pc has a lan cable for shared internet. The problem is the pc that conects to the phone point/internet needed xp pro to be reinstalled as it became corrupt and ever since I got the internet working again on the other computer I get constant traffic across the lan, like 4000 packets in 20 minutes sent, anyone with some network knowledge help? Link to comment https://www.fordxr6turbo.com/forum/topic/20964-pc-prob/ Share on other sites More sharing options...
Honest Gaza The Thief of BadGags Donating Members 527 Member For: 21y 7m 19d Location: Sydney Posted 27/10/05 07:15 AM Share Posted 27/10/05 07:15 AM I'm no Network expert, but you've confused me a little with your explanation.I'm assuming that the ADSL line terminates directly into the HUB/Router, and the 2 PC's also connect to the same HUB/Router.If so, is either PC connecting to the Internet ok ?If not, are the 2 PC's connecting via the LAN ok ?More info please. Link to comment https://www.fordxr6turbo.com/forum/topic/20964-pc-prob/#findComment-309022 Share on other sites More sharing options...
Typhoon Member 564 Member For: 20y 7m 27d Gender: Male Posted 27/10/05 07:18 AM Share Posted 27/10/05 07:18 AM working on it Link to comment https://www.fordxr6turbo.com/forum/topic/20964-pc-prob/#findComment-309024 Share on other sites More sharing options...
Honest Gaza The Thief of BadGags Donating Members 527 Member For: 21y 7m 19d Location: Sydney Posted 27/10/05 07:23 AM Share Posted 27/10/05 07:23 AM I had a similar problem when No.1 Son had to reload his OS. While my PC continued to connect to the Internet / LAN, his couldn't.His PC didn't work with DHCP but whn I assigned an IP address, all was ok.Once I was able to connect his PC to the Internet, I downloaded the latest drivers for his inbuilt LAN chip....and then DHCP worked beautifully.Could be similar problem ?????That's why I asked for more info. Link to comment https://www.fordxr6turbo.com/forum/topic/20964-pc-prob/#findComment-309026 Share on other sites More sharing options...
Typhoon Member 564 Member For: 20y 7m 27d Gender: Male Posted 27/10/05 07:24 AM Share Posted 27/10/05 07:24 AM NT TURBO said: I have a basic network at home, one pc connected to adsl usb modem other pc has a lan cable for shared internet. The problem is the pc that conects to the phone point/internet needed xp pro to be reinstalled as it became corrupt and ever since I got the internet working again on the other computer I get constant traffic across the lan, like 4000 packets in 20 minutes sent, anyone with some network knowledge help?<{POST_SNAPBACK}>I’m doing a diploma in network engineering at the moment I might be able to help.Firstly WOW it could be so many things, ok um what O/S are you running on both PCs? I need more info on you LAN cable is it a cross over cable or a straight through cable (twisted pair). Is the LAN cable plugged into a switch or is it a duel port modem.Look now that I read your post again I simply need more info tell me all that you can about your network. Cabling, Modem, Switches, O/S, software installed on both PCs including anti virus and additional fire wall protection is XP Pro on both machines. Link to comment https://www.fordxr6turbo.com/forum/topic/20964-pc-prob/#findComment-309027 Share on other sites More sharing options...
NT TURBO Member 1,128 Member For: 22y 2m 5d Gender: Male Location: Darwin NT Posted 27/10/05 09:12 AM Author Share Posted 27/10/05 09:12 AM ok, 2 pc's, one at the phone point has an adsl modem into the usb port, runs xp pro, both computers have nic cards and I have a crossover cable between them, pc 2 is xp home. beyond that I run the network set up wizard on both till it works, and it took quite a few attempts this time? Link to comment https://www.fordxr6turbo.com/forum/topic/20964-pc-prob/#findComment-309063 Share on other sites More sharing options...
NT TURBO Member 1,128 Member For: 22y 2m 5d Gender: Male Location: Darwin NT Posted 27/10/05 09:14 AM Author Share Posted 27/10/05 09:14 AM ....and as I say its now working so I have internet on pc2 but after them being connected for 3 hrs now I am up to 47,000 packets, the tray icon is constantly lit. Link to comment https://www.fordxr6turbo.com/forum/topic/20964-pc-prob/#findComment-309064 Share on other sites More sharing options...
marc86au Member 26 Member For: 20y 5d Posted 27/10/05 09:19 AM Share Posted 27/10/05 09:19 AM is there still network traffic when you unplug the internet connection from pc one? it could be that your 2nd pc has a program accessing the internet, could be a legitimate program updating, or it could be some form of spyware Link to comment https://www.fordxr6turbo.com/forum/topic/20964-pc-prob/#findComment-309066 Share on other sites More sharing options...
Honest Gaza The Thief of BadGags Donating Members 527 Member For: 21y 7m 19d Location: Sydney Posted 27/10/05 09:20 AM Share Posted 27/10/05 09:20 AM Could be doing any of the following from the Internet :Installing Service Pack updates for OSInstalling Virus Software updatesLet's hope it's not installing a Virus With the connection to ADSL removed....does the activity continue ? Link to comment https://www.fordxr6turbo.com/forum/topic/20964-pc-prob/#findComment-309067 Share on other sites More sharing options...
NT TURBO Member 1,128 Member For: 22y 2m 5d Gender: Male Location: Darwin NT Posted 27/10/05 09:30 AM Author Share Posted 27/10/05 09:30 AM Hmmm, the traffic stopped, then it reconnected itself?? Link to comment https://www.fordxr6turbo.com/forum/topic/20964-pc-prob/#findComment-309070 Share on other sites More sharing options...
