ColinT Donating Members 372 Member For: 20y 4m 21d Posted 24/10/05 10:54 AM Share Posted 24/10/05 10:54 AM Has anyone have this happen?In the last week I have started to use the AC more. After it has been operating for a while, then it is turned off, the smell starts.I went to the dealer today and was told the smell is due to a bacteria on the AC core in the dash and there is nothing they can do about it. They say I should have used the AC more and it wouldn't have happened.The next suggestion they showed me was to lower the glove box remove the leaf screen and spray Glenn 20 into the fan inlet when it is operating.Any suggestions from the forum? Link to comment https://www.fordxr6turbo.com/forum/topic/20901-air-conditioner-smell/ Share on other sites More sharing options...
hafadude Donating Members 245 Member For: 20y 1m 9d Gender: Male Location: Cairns Qld Posted 24/10/05 01:38 PM Share Posted 24/10/05 01:38 PM Hey Coln T,have a look at this old thread:http://www.fordxr6turbo.com/forum/index.ph...topic=18040&hl=My problem seems to have disappeared after a few months of use, thank goodness! Link to comment https://www.fordxr6turbo.com/forum/topic/20901-air-conditioner-smell/#findComment-308153 Share on other sites More sharing options...
Guest chrisf6 Guests Posted 26/10/05 12:59 AM Share Posted 26/10/05 12:59 AM I have the same problem in my wifes sportivo, as the F6 remains a weekend carfirst thing in the morning when I start up,phwooooo,only lasts for a few seconds,this got me thinking,I allways have the a/c on,even in winter so the core never gets to dry out,allways cold and dampso last night I took it for a 30min drive with the heater on full tilt,max fan and max heat,wound down all the windows to avoid cooking myself,with the a/c on aswellthought I could burn off any crap in therewell well well,start the car this morning with the a/c on cold as usuall,presto no smellgive it a go,it seemed to work for me Link to comment https://www.fordxr6turbo.com/forum/topic/20901-air-conditioner-smell/#findComment-308587 Share on other sites More sharing options...
cqae Member 229 Member For: 21y 7m 17d Posted 26/10/05 02:21 AM Share Posted 26/10/05 02:21 AM heaps of places do an a/c system deodouriser, is readily available from repco & bursons. use it often and it works ok.unfortuneately the a/c box is the perfect breeding ground for bacteria-cold, dark +moist. so u might have to use every now and then. u can also shoot in in through where the pollen filter/mesh is. Link to comment https://www.fordxr6turbo.com/forum/topic/20901-air-conditioner-smell/#findComment-308622 Share on other sites More sharing options...
Macktheknife Xtreme Xalted Member Donating Members 3,112 Member For: 22y 1m 16d Gender: Male Location: BrisVegas Posted 26/10/05 02:36 AM Share Posted 26/10/05 02:36 AM Also, try to run the A/C on the fresh air setting rather than the recirc.'cept if ya happen ta be following Scotty....... Link to comment https://www.fordxr6turbo.com/forum/topic/20901-air-conditioner-smell/#findComment-308629 Share on other sites More sharing options...
BAXTCHROME Member 16 Member For: 19y 10m 17d Posted 26/10/05 02:53 AM Share Posted 26/10/05 02:53 AM Be careful opening it up. I got some leaves caught in my fan and it wrecked the whole thing. Had to get a new one... Link to comment https://www.fordxr6turbo.com/forum/topic/20901-air-conditioner-smell/#findComment-308631 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 1m 28d Gender: Male Location: Brisbane Posted 26/10/05 04:28 AM Share Posted 26/10/05 04:28 AM Macktheknife said: Also, try to run the A/C on the fresh air setting rather than the recirc.'cept if ya happen ta be following Scotty....... <{POST_SNAPBACK}>Your a harsh man Trev - what's wrong with the LPG taxi smell? Link to comment https://www.fordxr6turbo.com/forum/topic/20901-air-conditioner-smell/#findComment-308670 Share on other sites More sharing options...
ColinT Donating Members 372 Member For: 20y 4m 21d Posted 27/10/05 06:23 AM Author Share Posted 27/10/05 06:23 AM Did the Glenn 20 spray into the fan intake. Have been using the AC frequently since and the smell seems to be gone. Should I say both smells, the stale water smell and the Glenn 20 smell.Colin Link to comment https://www.fordxr6turbo.com/forum/topic/20901-air-conditioner-smell/#findComment-309013 Share on other sites More sharing options...
