Guest hank
  • Guests
Hey guys I am just wondering if ne of you's know the Wheel offsets for the xr6t??
I know somone said that the PCD is 5/114.3 but I need the offsets.
all info is appreciated
thankz    :msm:
muzza
<{POST_SNAPBACK}>
I'm pretty sure there's one offset on each corner of the car Muzza, but I don't have my car here to check. I think there's one offset in the boot somewhere too (sounds crazy, but I believe it's true).
Hope that helps,
.... Gordon.
https://www.fordxr6turbo.com/forum/topic/20866-offsets/#findComment-307596
  • Member For: 22y 6m 26d
Ford say 32-40mm. Generally the lower the rim width the lower the offset so that all cars in the range have approximately the same track. The 17'x8" and 18"x8" used on the XRs are 36.5mm on the AUs but as yet I haven't measured a BA rim although I believe they would be the same.
https://www.fordxr6turbo.com/forum/topic/20866-offsets/#findComment-307691
so +40mm for the 19x9.5 and 19x8's would fit??
thankz
muzza
<{POST_SNAPBACK}>
Yes, but the clearance on the fronts will be very tight on the upper balljoint.
https://www.fordxr6turbo.com/forum/topic/20866-offsets/#findComment-307735
