C.S.I Member 651 Member For: 20y 6m 17d Gender: Male Location: Gold Coast Posted 05/10/05 01:13 PM Share Posted 05/10/05 01:13 PM I made 45rwkw with just the Box, albiet it was custom 9 or so PSI tuned. Not a capa standard tune. Link to comment https://www.fordxr6turbo.com/forum/topic/20499-capa-flash-tuner/page/2/#findComment-301956 Share on other sites More sharing options...
ColinT Donating Members 372 Member For: 20y 5m 1d Posted 05/10/05 07:39 PM Share Posted 05/10/05 07:39 PM (edited) I have never heard of the edit standard tunes causing damage. I looked at all these options when I decided to persue edit. But it was pretty clear that the only way to achieve the full potental was a custom tune.If your going to spend $995 then allow the extra $500 for the tune, I have. Edited 05/10/05 07:41 PM by ColinT Link to comment https://www.fordxr6turbo.com/forum/topic/20499-capa-flash-tuner/page/2/#findComment-301987 Share on other sites More sharing options...
rushed6 Member 137 Member For: 19y 10m 9d Gender: Male Location: Victoria Posted 06/10/05 02:44 AM Share Posted 06/10/05 02:44 AM hey dont kill the messanger that is what I was told by simon at nizpro Link to comment https://www.fordxr6turbo.com/forum/topic/20499-capa-flash-tuner/page/2/#findComment-302095 Share on other sites More sharing options...
ZMAN Member 669 Member For: 22y 2m 2d Location: Inglewood, W.A Posted 06/10/05 03:01 AM Share Posted 06/10/05 03:01 AM I got approx 35kw at the rears...with the generic tune and plug regap @ 10psi. Link to comment https://www.fordxr6turbo.com/forum/topic/20499-capa-flash-tuner/page/2/#findComment-302102 Share on other sites More sharing options...
geea Site protagonist Lifetime Members 4,320 Member For: 22y 1m 21d Gender: Male Location: At the lights, waiting for you. Posted 06/10/05 09:28 AM Share Posted 06/10/05 09:28 AM The 8 and 10psi tunes that come with the box won't hurt your car. They are conservative as to allow for the tolerances that Ford has. As has been metioned stock "T's" can vary a bit, 170-200rwkw's. If your car is starting from a low base then the gains will be greater than if you have a car that is one of the better ones.If you can afford it buy the box and get 3 custom tunes at the same time. This should cost around the $1500 mark. Get the tunes to suit your needs. A valet map, different octane maps, wife map race map. Choose which you need. The tuner is very important. A bad tuner will still give you a bad tune no matter how good the software. Not sure where you are, it's probably best to talk to a few of the guys in your area and if possible go for a few drives to actually experience different tuners tunes.Geea. Link to comment https://www.fordxr6turbo.com/forum/topic/20499-capa-flash-tuner/page/2/#findComment-302228 Share on other sites More sharing options...
xrdreaming Lifetime Members 1,693 Member For: 22y 5m 3d Gender: Male Location: Melbourne Posted 06/10/05 09:34 AM Share Posted 06/10/05 09:34 AM Ahhh sound advice grasshopper Link to comment https://www.fordxr6turbo.com/forum/topic/20499-capa-flash-tuner/page/2/#findComment-302230 Share on other sites More sharing options...
geea Site protagonist Lifetime Members 4,320 Member For: 22y 1m 21d Gender: Male Location: At the lights, waiting for you. Posted 10/10/05 09:20 AM Share Posted 10/10/05 09:20 AM The 8 and 10psi tunes that come with the box won't hurt your car. They are conservative as to allow for the tolerances that Ford has. As has been metioned stock "T's" can vary a bit, 170-200rwkw's. If your car is starting from a low base then the gains will be greater than if you have a car that is one of the better ones.If you can afford it buy the box and get 3 custom tunes at the same time. This should cost around the $1500 mark. Get the tunes to suit your needs. A valet map, different octane maps, wife map race map. Choose which you need. The tuner is very important. A bad tuner will still give you a bad tune no matter how good the software. Not sure where you are, it's probably best to talk to a few of the guys in your area and if possible go for a few drives to actually experience different tuners tunes.Geea. <{POST_SNAPBACK}>I've been told that under extreme driving conditions that the fuel system may not be able to keep up with higher power maps. By extreme I believe driving at 180kmph+ for prolong periods.This won't be relevant to most people but for those that would do this sort of driving upgrading the fuel pump could be an option.This isn't from my own experience. I have been told this and am passing it on.Geea. Link to comment https://www.fordxr6turbo.com/forum/topic/20499-capa-flash-tuner/page/2/#findComment-303444 Share on other sites More sharing options...
JB Forum Superhero Donating Members 3,109 Member For: 21y 7m 6d Location: Eastern Suburbs of Mexico Posted 10/10/05 11:18 PM Share Posted 10/10/05 11:18 PM The 8 and 10psi tunes that come with the box won't hurt your car. They are conservative as to allow for the tolerances that Ford has. As has been metioned stock "T's" can vary a bit, 170-200rwkw's. If your car is starting from a low base then the gains will be greater than if you have a car that is one of the better ones.If you can afford it buy the box and get 3 custom tunes at the same time. This should cost around the $1500 mark. Get the tunes to suit your needs. A valet map, different octane maps, wife map race map. Choose which you need. The tuner is very important. A bad tuner will still give you a bad tune no matter how good the software. Not sure where you are, it's probably best to talk to a few of the guys in your area and if possible go for a few drives to actually experience different tuners tunes.Geea. I've been told that under extreme driving conditions that the fuel system may not be able to keep up with higher power maps. By extreme I believe driving at 180kmph+ for prolong periods.This won't be relevant to most people but for those that would do this sort of driving upgrading the fuel pump could be an option.This isn't from my own experience. I have been told this and am passing it on.Geea. Do we feel like wise old men? I'll just go get my Pipe...... Link to comment https://www.fordxr6turbo.com/forum/topic/20499-capa-flash-tuner/page/2/#findComment-303635 Share on other sites More sharing options...
